928 Forum 1978-1995
Sponsored by: 928 Specialists
cam gear
Old 03-16-2017, 06:01 PM
polcan
polcan's Avatar
Default cam gear
what are my options for cam gears 1988 928 S4 ?
Old 03-16-2017, 06:18 PM
jeff spahn
jeff spahn's Avatar
call Roger at 928srus. He has them. Get them and don't dink around with used.
Old 03-16-2017, 06:23 PM
Simon928
Simon928's Avatar
If your gears have just started to wear through the coating and you just see a hint of metal showing through you might be able to re-coat them. The edges of the gear teeth still have to be straight, and you can check this by holding a straight edge up to them. I got mine re-coated by a place out in Erin called Fireball Coatings for around $100 if I recall correctly.
Old 03-16-2017, 06:34 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,070 Likes on 1,182 Posts
I re-coated the gears on my 87. At about 100k miles the coating was just starting to show signs of wearing off.
Old 03-16-2017, 08:24 PM
polcan
polcan's Avatar
Mine are pass point of return,no coating can save them .I called Roger already. Does 928 Motorsport still make them ? Can't find them on web site?
Old 03-17-2017, 12:36 PM
Carl Fausett
Developer
Carl Fausett's Avatar
No, we do not. It was one of those things that made sense at the time because they were NLA from Porsche. Then Roger started making them, and new ones became available direct from Porsche too.
We figured the available market for this part was too small to support three suppliers, so we dropped it.
Old 03-17-2017, 05:56 PM
polcan
polcan's Avatar
Hello
what do you think about these ones , $ 250.00 each or porsche OEM for $539.00
CDN each .The only problem is one is 928 105 530 01 (the better looking one with correct part number) and other 928 105 530 00 with a bit of wear .Are they interchangeable ? I think they were superseded by 928 105 530 04
Old 03-17-2017, 05:59 PM
polcan
polcan's Avatar
ohmy my forgot to insert picures
928 105 530 00
928 105 530 01
Old 03-17-2017, 06:06 PM
davek9
davek9's Avatar
Those could be re-coated, however you will need to add in the cost and Time of getting that done and hopefully they do a good and correct DL coating job.
Or.. call 928sRUs (Roger), last time ~ a month ago, I bought them his price was better than what you listed for New OEM.
Dave K
Old 03-17-2017, 06:54 PM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,451 Likes on 1,459 Posts
Totally depends on how long you want to drive the car and what your intentions are.
If you are going o drive it another 75,000 miles, buy new ones, from Porsche (or Roger.)
If you are going to drive it for another 50,000 miles, buy a set of gear that are barely showing the aluminum through the coating (like the ones offered, above) and have them re-coated.
I've got boxes full of those....$150.00 each
If you are going to drive it for another 30,000 miles, find a good used set that still have good coating. (Rare to find.)
I've got a really nice used set that have no signs of the aluminum coming through....$200 each.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
Old 03-17-2017, 09:02 PM
ROG100
Basic Sponsor
ROG100's Avatar
My current price is $406 each and it is not going to get any cheaper.
Old 03-18-2017, 08:01 AM
Bigfoot928
Bigfoot928's Avatar
another thing that makes the new ones more attractive is that they seem to be made of better material.
Old 03-18-2017, 01:14 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
When I had them in my hands, the new ones looked like they are not cast but machined from a solid piece of aluminum and the coating seems to be a different material than before. Perhaps they are more durable than before.
Old 03-18-2017, 01:54 PM
davek9
davek9's Avatar
I know, they are to nice looking to hide under those covers
Old 03-20-2017, 10:21 AM
ROG100
Basic Sponsor
ROG100's Avatar
The new gears were re-designed by Porsche about three years ago to overcome the wear issues on the older "softer" gears with the spray on wear coating.
The new gears are made of a much harder alloy and are hard anodized. If the belt is maintained correctly then I doubt these gears will wear out for a LOOOOOOOOOOOOOOG time.
The oil pump gear is now steel (has been for a few years now) so again less chance of wear.
Quick Reply: cam gear
