Things to Check Specifically for an early GTS car
Quick questions for the masses:
Besides the issues with crank end play, thrust bearing, WP/TB, fuel lines, power steering lines, etc for all Porsche 928 potential purchases, what specific items are needed to be addressed for early GTS models? Specifically early '93 auto?
thanks
Hoi
thanks
Hoi
Basic Site Sponsor
Basic Site Sponsor
thanks
Hoi
thanks
Hoi
Top of piston inspection for carbon from excessive oil consumption.
Time of engagement when shifting into reverse....Reverse band material wears rapidly in some 1993 models.
Camshaft deterioration (valve covers must be removed to see this) caused by high oil temperatures.
Damage to front oil cooler, front oil cooler protection piece, front valance, and undertray from bottoming out.
Rear wheels bent and cracked from hitting relatively minor potholes on thie inner rim.
14 pin wiring loom deterioration.
Head gasket deterioration from coolant not being changed often enough and car sitting.
I have a late '93, but the one "gotcha" I had was a crappy PSD. I know it's not specific to a GTS, but if you're looking for things to really look at during a PPI, I'd add it to the list. That was an unexpected $1.5 - $2K to get that all sorted out.
