Ground wire under shifter
There is a knife connector under the shift indicator on the driver's side of the shifter between the indicator illumination bulbs. It has a frayed and broken brown wire attached to it. Where does the other end attach? It has been broken as long as I have had the car. 1984 928S automatic.
