Won't tach out.
Won't tach out.
Did the plugs and wires on my 85 s3 5.0L, the old ones were some split Grove crap,that had been in the car for some ,anyway put Bosch iridium, in the car now the car won't Rev past 5k, I haven't done the cap and rotors yet, everything was great before the plugs and wires exchange. Any advice.thanks in advance.
I thought that the iridium plugs would burn better, the car honestly feels like it's governed, she won't pull past 5k.
Check the Coil ends (look inside too), then use a Temp gun and make sure all 8 are getting hot, if not then use an inductive timing light on each plug wire to see if its getting spark.
IMO: Plugs "Bosch WR7 DC +", Caps and Rotors should all be done at the same time, (all wear items) to keep proper electric loading/resistance on the Ignition system.
If all the sensors are good w/ clean connections, that is 99% of the tune-up.
Edit: How was it running before you did the initial work?
Dave K
Dave K
Dave K
Dave K
