928 Forum 1978-1995
Sponsored by: 928 Specialists
Fuel line warning
Old 03-26-2017, 02:59 AM
Bambalam
Bambalam's Avatar
Default Fuel line warning
Hi everyone, a quick introduction - my name is Simon, bought my first 928 a year ago and have been completing an intake refresh and all the other issues that affect these cars.
The two flexible fuel lines have been replaced on my car and I thought everything should be OK but worth checking. On inspection of the solid or hard fuel line that runs from the right hand side strut tower to the fuel pressure regulator at the front left side of the motor I noticed a rust patch under the rubber support area on the line. I ran the fuel line under the wire buff wheel and you can imagine my surprise when I spotted the pinhole as shown in the photo below. So just because you have changed your flexible fuel lines always check then all.
I would like to say thanks to everyone for all the advice offered on this forum and thought this is my chance to pass on an issue I have discovered (I hope there isn't another thread about this).
Old 03-26-2017, 06:00 AM
worf928
worf928's Avatar
Received 1,542 Likes on 1,006 Posts
Good catch!
Old 03-26-2017, 07:23 AM
M. Requin
M. Requin's Avatar
Good work, and thanks for the post.
Old 03-26-2017, 08:18 AM
928S MN
928S MN's Avatar
Chloride pitting attack from some South Pacific sea salt perhaps?
Great catch and thanks for posting this. Exact model year of your 928?
Old 03-26-2017, 11:58 AM
Captain_Slow
Captain_Slow's Avatar
Interesting...I'm pretty sure you are the first to report this failure point. I originally ordered the stock style hose that Greg makes. I received the alternate style that does away with the hard line, and let Roger know I was fine with the alternate design. Your post makes me more satisfied with the decision.
Old 03-26-2017, 08:29 PM
Kiwi'79
Kiwi'79's Avatar
Good stuff, thanks for posting.
However, not to over analyse, the perforation looks remarkably uniform, along with a slight "indentation/inward creasing" surrounding the hole, maybe the photo playing tricks?
The reason I bring this up is just in case there is some debris or deformation in the clamp area, that may press into your new lines creating the same problem, FYI.
Old 03-26-2017, 10:27 PM
Whitesands
Whitesands's Avatar
Had the same problem on my 88S4, a lot of corrosion on the pipe and clamp, replaced with a good used item, can't remember if I reported it to the list.
Old 03-26-2017, 10:32 PM
Captain_Slow
I noticed this also. Almost looks like it was drilled. The only kind of corrosion I've seen pitted like this is bimetallic corrosion....the metal kind of erodes just at the point of contact.
Old 03-26-2017, 11:42 PM
Bambalam
Bambalam's Avatar
Not a problem Guys, I am happy to contribute back to this forum for all the help I have received.
My car is a 90 S4 and this car has spent most of its life somewhere near the ocean - this car has also spent some periods of its life sitting (the steering rack shaft is also showing signs of water sitting and causing corrosion).
I would believe that the clamp and moisture held within would have caused this corrosion - hence why the clamp was removed.
Interesting observation on the corrosion surrounding the hole - yes there is definitely noticeable creasing around the hole - not sure if this is just more corrosion or if the metal is failing, almost looks like a drill hole.
Old 03-27-2017, 12:17 AM
SteveG
SteveG's Avatar
Whitesands, there is a pretty bird sitting on your Jaguar.
Quick Reply: Fuel line warning
