Keys lost. No more keys in my possesion
I lost my keys. I have no other keys. Car is in a warehouse where I can work on it. I think I left them there and someone else found them. Luckily the car is immobile. But I have the rear hatch closed with a lot of my stuff (parts, some tools) inside. Doors are unlocked (windows open). The car is under a cover.
Can I buy new keys when I show the registration papers to the dealer?
If you have a photograph of the ignition key or any other, there are companies which can make you a replacement from the photo. Much cheaper than getting one from Porsche. I have had three keys cut from photos which work perfectly.
If not you should certainly take a photo first thig when you get your new key.
Yes, the dealer can order a replacement key by VIN. It takes a while, and there have been some reports of such keys not working, but I suspect the dealer will work with you if you have problems.
http://keys4classics.com/html/Por928.html
Best keys from a photo. Had several made over the years. Fast shipping from Australia.
Dealer can make a key off of the VIN. If the ignition has been changed, or the records are wrong (and some are), it won't work.
I had one made that worked fine.
Not cheap at $90. And while they insisted on proof of ownership for a key for my 944, they didn't for the 928 (same dealer, different people).
Alternatively, Roger can have them made from the VIN too.
Received 1,207 Likes
I tried to get a key with the VIN at my local dealer.
After two keys that didn't work, we quit.
They suggested me to try a local shop in Ottawa.
It worked... But only after they fixed the ignition they messed with.
They kept the car for a few days.
That key was not profitable at all for them...
I've had good luck with getting a new key from Porsche.
The only thing you need to make sure is that your car still has the original locks and that they have not been rekeyed. That's where a lot of people have had issues.
