928 Forum 1978-1995
Sponsored by: 928 Specialists
Headlight / Foglight interaction prob with LED bulbs
Old 03-13-2017, 04:37 PM
M. Requin
M. Requin's Avatar
Originally Posted by davek9
I can confirm that swapping the Fog Lamp Relay with a standard type 53 also works for 'USA' '85 through '86.5 MY's.
I have all three MY's running with LED's and no issues with feed back.
Glad to hear you got this issue easily sorted Mike
Dave K
Dave, did you make any mod other than swapping in a 53?
Old 03-13-2017, 05:05 PM
Alan
Electron Wrangler
Alan's Avatar
This same issue affects local headlight relays for the same reasons. I'd recommend you try this fix (depending on year of your car).
Alan
Old 03-13-2017, 05:12 PM
davek9
davek9's Avatar
Hi, I did not do anything other that swap out the Fog Light Relay, on my '85, '86 and an '86.5.
Dave
Old 03-15-2017, 09:18 AM
M. Requin
M. Requin's Avatar
Thanks Dave! I'll give it a try. And BTW, I am pleased that my 3000th post is a "thank you". What a group.
Old 03-16-2017, 05:14 PM
Randy V
Randy V's Avatar
So did the OP fix his problem?
Old 03-17-2017, 01:18 AM
Michael Benno
Michael Benno's Avatar
Yep. Problem solved!!
Old 08-25-2017, 08:38 PM
Glen McCartney
Glen McCartney's Avatar
I just had the same issue when installing LED's in my MY85 and swapping in a regular 53 relay solves the issue with the hi beams coming on when the fog lights are switched on.
Old 08-25-2017, 09:32 PM
Ed Scherer
Ed Scherer's Avatar
Thanks, Michael and Alan. This (replacing the fog light relay with a 53 relay) is a nice, easy-to-implement, inexpensive modification that has the additional benefit of allowing all the bulbs up front to illuminate simultaneously.
I don't see any downside to this, other than perhaps slightly raising the possibility of cracking the lenses from excess heat if you're running all the halogen H3s (especially higher-than-stock ones) concurrently.
Old 06-02-2018, 02:43 AM
928Myles
928Myles's Avatar
Hi, I just tried to install the LED H4 bulbs in my ex Japan 1990 ROW S4. Used Ed's caps and phillps chipped LED's.
Everything light wise is stock standard. Fog lights turn off if high beam selected.
Headlight switch assembly just dismantled and cleaned.
Main headlight relay fairly new.
I have a 53 type relay in position IV (fog lights). Swapped in new spare to make sure it was working.
As soon as I switch the fog lights on ( switch on pod pressed in, light switch turned to 1st or 2nd position) the headlights go to main beam and will not dip.
Normal function if I leave 1 halogen bulb in place or have the fog lights (pod switch) turned off.
Any ideas?
Myles
Old 06-02-2018, 01:17 PM
Michael Benno
Originally Posted by 928Myles
LED H4 bulbs
Japan 1990 ROW S4
Myles
This does sound peculiar. My first thought would be to double check the relay position and make sure you are replacing the correct one. We all have been fooled more than once with the socket numbering. Look for the little arrow to indicate which direction the roman numerals are referring to.
The second course of action I would recommend is to replace the original relay and see if you can replicate the condition in the original post. That will give you a clue if your system is wired the same as my 88. As Alan indicated there were some model specific wiring configurations.
The next thing I would consider is try the system without the foglight relay. Does that solve your issue? Hopefully Alan can chime in since he seems to better understand the wiring variations for the different model years. Keep us informed
Old 06-02-2018, 01:21 PM
Michael Benno
Oh one more thing, since your car is a Japan model, does your car have daytime running lights? IIRC, 1990 Japan and ROW cars had daytime running lights. Check out this post on the modification to enable this: https://rennlist.com/forums/928-foru...nger-cars.html
if your car has the DRL then maybe this is causing interaction problems. Try removing this relay for the DRL and see if you can get your system to work with the fogs.
Old 06-02-2018, 02:03 PM
Alan
Electron Wrangler
Alan's Avatar
Myles - do you have fear fogs? does their status (on/off) affect anything. The Japan configuration is a slight hybrid of ROW & USA.and has this different feature
Generally it seems the '90 is similar to the '88 for fog configuration... can you post a picture of your original fog relay (pin side view and part #)
Alan
Old 06-02-2018, 04:04 PM
928Myles
928Myles's Avatar
Michael / Alan.
I have verified that I was determining the correct fog light relay position.
I do not have the relay for daytime running lights.
I do have rear fog lights. Their on/off status does not affect anything main light wise.
I will extract the fog relay and post a picture later today (it is dark out at the moment)..
Myles
Old 06-04-2018, 12:43 AM
928Myles
928Myles's Avatar
Photo of relay below. Part numbers / markings:
141 951 253B
22 300 007
WLO Germany
12V 40A
Pin Layout:
.........--- ...............86
..---.......... | ....30 ........87
.........--- ...............85
Cheers
Myles
Old 06-04-2018, 11:53 AM
Alan
Electron Wrangler
Alan's Avatar
If your car came with a standard 53B relay in that position then its possible they swapped the wiring around and the 2 relays now are placed in reverse between USA/Japan and ROW...? that seems an odd change to make.
Can you check the 85 terminal in the fog relay socket - is it a permanent ground - or does it switch with the high beam? If it does switch with the high-beam - maybe you need the special relay removed by Michael above...?
Alan
Quick Reply: Headlight / Foglight interaction prob with LED bulbs
