928 Forum 1978-1995
Sponsored by: 928 Specialists
A tale of two water necks...
Old 02-24-2017, 10:04 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,243 Likes on 1,241 Posts
JB weld it save your money for other parts.
use some 400 grit paper on the tube and insert,
clean it with acetone,
then JBweld it,
I guarantee it will never come apart
Old 02-26-2017, 01:09 AM
karl ruiter
karl ruiter's Avatar
Give it a Feynman test. Bond a blob of JB weld to aluminum drop it in a cup of boiling water, then pull it out and poke it with a screwdriver while it is hot. I suspect you will elect not to use JB weld in this application.
Old 02-26-2017, 10:04 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
never thought a water outlet would be a part of a Feynman discussion.
https://www.google.com/url?sa=t&rct=...ZKdniRH3DVtSQQ
Old 02-26-2017, 11:12 AM
the flyin' scotsman
the flyin' scotsman's Avatar
Is he one of Sheldons friends on BBT?
Same piece came apart on my S4; JB welded back together, refitted and has been that way for many years and thousands of kms
Porsche does have a reputation for using 'glued' parts......ask the Cayenne group
Old 02-26-2017, 11:18 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
I have fixed 4 of them so far no leaks
Old 10-14-2017, 11:59 PM
skpyle
skpyle's Avatar
Note, all further work done to the engine and accessories on the Red Witch will be documented in this thread:
https://rennlist.com/forums/928-foru...l#post14536481
Old 10-19-2017, 11:03 AM
Tom in Austin
Tom in Austin's Avatar
Good grief, never thought I'd have to worry about nipple migration! Can you tell by model year which kind you have?
Old 10-19-2017, 11:48 AM
davek9
davek9's Avatar
Just went through this earlier this summer, dam thing came apart and sprayed G-05 coolant all down the back of my SC engine, bell and headers, what a mess to clean that stuff off.
Thought about gluing it but not wanting to chance another future failure as the newer part is less than 40 bucks!
If you really want to save the old ones then get it welded like the 911 guys do.
Just my 928 cents
Dave K
Old 10-19-2017, 12:11 PM
hans14914
hans14914's Avatar
I could whip up a batch of billet ones if there is a need
Old 10-19-2017, 12:20 PM
davek9
davek9's Avatar
Thought about that Han's but would they be less $ than the newer ones?
They are not NLA as far as I know, and although Billet would be great looking and a cool solution, you can't see them when installed.
Old 10-19-2017, 12:30 PM
polecat702
Vegas, Baby!
polecat702's Avatar
I didn't read all the suggestions, but here's my advice. I've been a certified welder for over 50 years. Plus I teach at the local Jr. collage.
A quick solution, and one that will work, Tap the water bridge with a suitable pipe tap, and use a pipe nipple to hose fitting. Use some expando, pipe joint compound, amd believe me it'll never come apart. Outlast the engine and the car.
Old 10-19-2017, 12:31 PM
Chris Lockhart
Chris Lockhart's Avatar
Would be beautiful, but like you said Dave, you can't see it, so it's not worth it.
Quick Reply: A tale of two water necks...
