928 Forum 1978-1995
Sponsored by: 928 Specialists
Replace rack end of PS return line
Old 02-15-2017, 12:09 AM
skpyle
skpyle's Avatar
Default Replace rack end of PS return line
Hello Gentlemen,
As part of my I-should-know-better-but-I'm-going-too-far work on my 928, I am replacing all the PS system hoses. I have a new Porsche PS pressure hose. I have seen in numerous write-ups that people dremel off the crimp on the reservoir end of the return line and replace the rubber hose with bulk hydraulic hose.
No problem, I am going to do the same thing.
Well...tonight, I removed both line assemblies from the car. I noticed there is a short 90 degree rubber hose on the rack end of the PS return line.
What are people doing to replace this? I see that there is a coil, maybe a spring, around this short rubber hose. Could I use bulk hydraulic hose and use the coil to keep it from kinking as it bends the 90 degrees?
PS return line assembly.
Reservoir end of the PS return line assembly. This rubber hose is commonly replaced with bulk hydraulic hose.
Rack end of the PS return line assembly. Not sure if the coil is used to support the rubber hose and keep it from kinking. I would like to replace this with bulk hydraulic hose.
Seth K. Pyle
Old 02-15-2017, 01:13 AM
The Forgotten On
The Forgotten On's Avatar
It has no pressure so it would be safe to use a hose clamp on and not have a large risk of leaking however you should crimp on new hose (bulk hydraulic will work perfectly) metric size is preferred.
The coil is used to prevent kinking just like on the rear brake lines.
Old 02-15-2017, 02:28 AM
NC928S4
NC928S4's Avatar
I recently replaced this line and followed Dwayne's instructions which you may have already stumbled on.
I found getting the alternator out of the way the biggest PITA which required Fan shroud loosening and bottom radiator hose removal. Clearance to get alternator bolts out required this.
A new dremel bit is necessary to cut out the old connectors. Dwayne's write up always makes it look easy but I found this seemingly simple replacement challenging and messy(coolant, PS fluid, and sparks from cutting).
Good luck.
Old 02-18-2017, 06:44 PM
skpyle
skpyle's Avatar
Sweet, thanks guys!
I will get another length of hydraulic hose and more clamps. I will clean up and reuse the spring to prevent kinking.
Seth K. Pyle
Old 02-19-2017, 04:33 PM
FredR
FredR's Avatar
Just about to try doing this myself so your pics helpful.
Rgds
Fred
Old 02-19-2017, 05:17 PM
skpyle
skpyle's Avatar
Hi FredR!
I was playing around with the length of hydraulic hose that I have for the reservoir end of the line. It had no trouble making the bends needed to reach the reservoir. As well, it had no problem making the 90 degree bend for the rack end of the line.
Good Luck!
Seth K. Pyle
Old 02-19-2017, 05:54 PM
ROG100
Basic Sponsor
ROG100's Avatar
Most buy a $15 PS reservoir to PS pump hose and cut a section from it that fits perfectly.
Molded to the right shape and exactly the same hose.
Easy Peasy!!
Old 02-19-2017, 07:29 PM
skpyle
skpyle's Avatar
Oh hell! That is brilliant.
Seth K. Pyle
Old 10-15-2017, 12:00 AM
skpyle
skpyle's Avatar
Note, all further work done to the engine and accessories on the Red Witch will be documented in this thread:
https://rennlist.com/forums/928-foru...l#post14536481
Old 10-15-2017, 03:48 PM
Ad0911
Ad0911's Avatar
Default PS hard lines replated
As you said, many people cut off the hoses and put on new ones. I plan to do the same. The hard lines are here somewhere...
Old 10-15-2017, 07:26 PM
skpyle
skpyle's Avatar
Excellent!
Old 10-16-2017, 09:39 AM
DeWolf
DeWolf's Avatar
I'm taking my hoses to a 'Hose Dr' and getting them to remove the old rubber sections and replace with braided lines. Cheap solution and they look cool too.
Old 10-16-2017, 10:01 AM
Chris Lockhart
Chris Lockhart's Avatar
Seth, I took mine to Cline Hose in Greenville, and had them rebuilt for $64.00. They did my GT as well years ago. Roger's plan of using the reservoir line for the end of the PS return is brilliant, and if you supply it, Cline will crimp it on. I went with bulk hose, then a hose spring to keep it from kinking when making the turn. Works great. I also have extra springs if you need one.
Old 10-16-2017, 02:05 PM
davek9
davek9's Avatar
Just as an FYI, the "spring" is not on there for anti-kinking, it's for anti-abrasion, like stones,
same on the brake lines,
I've been using the Roger's method for some time w/o any issues, main thing it to get the correct grade hose for Auto Trans fluid
Dave K
Old 10-16-2017, 02:47 PM
Chris Lockhart
Dave K
Dave I wasn't referring to the existing spring on the bottom of the line, rather the other end when using bulk hose. With bulk hose it tries to kink when you bend it downward to hook up with the mating pipe, so using an "anti-kink spring" on the hose helps to prevent this issue. That's what I've done and it works well. Pretty cheap as well, as the springs can be had for a couple of bucks.
Quick Reply: Replace rack end of PS return line
