928 Forum 1978-1995
Sponsored by: 928 Specialists
928S euro hard start and no running
Old 02-13-2017, 10:55 AM
GerritD
GerritD's Avatar
Default 928S euro hard start and no running
Hi 928 guys and girls,
After overhaul of 4.7 L Kjet 300Hp engine, almost impossible to start and when started very difficult to keep it running , also permanent blue-grey smoke from exhaust.
i followed the official WSM flowchart for troublesolving engine issues . All impedance and voltage measures of cables and electrical components were ok.
I checked WUR for debrie but filter ok, also Aux air valve is working .....help😜😢
could injection/air device be faulty because adjusting mixture and idle had no effect!
air plate is freely moving so plunger is not stuck. How to check this ?
strangely enough my engine worked fine for 2 days after the overhaul??? What could suddenly cause the excessive fuel and bad combustion? Compression on each cilinders is 11bar.
I am completely lost here...
Old 02-13-2017, 07:11 PM
GlenL
GlenL's Avatar
Year?
Old 02-13-2017, 07:39 PM
Randy V
Randy V's Avatar
I think you mean '928 guys, and Nicole'. She's pretty much the only 928 chick here on a regular basis.
Old 02-13-2017, 08:43 PM
michael j wright
michael j wright's Avatar
Just throwing this out there. Normally, blue-grey smoke would be oil, black smoke fuel, white smoke water. Sounds to me that you have started burning oil for some reason, I would start by pulling plugs and seeing if they look oil soaked or smell of fuel. I could be wrong on this so I would ask others to join in and correct me if this is wrong. Just my .02
Mike
Old 02-13-2017, 10:02 PM
GerritD
GerritD's Avatar
Originally Posted by GlenL
Year?
Porsche 928S of 09/05/1980
Old 02-13-2017, 10:11 PM
GerritD
GerritD's Avatar
perhaps interesting : before I had another engine in my 928 : 4.5L 240hp type M28.01 which was not the original engine, therefore I overhauled a 4.7L 300hp.
Both engines are CIS kjet euro, same ecu, same WUR, same aux air valve, same connections.
Only distributor is different and there are 2 extra components :
- hotstart valve
- fuel pressure damper
Could the excessive unburnt fuel be related to one of both components that have become faulty?
Old 02-13-2017, 10:38 PM
SwedeInSiam
SwedeInSiam's Avatar
What engine do you have?
1980 RoW S don't have a ecu.
Old 02-13-2017, 10:40 PM
GerritD
GerritD's Avatar
with Ecu, I meant the control unit for the ignition pulse
Old 02-13-2017, 10:41 PM
GerritD
GerritD's Avatar
engine type M28.12 , 4.7 L 300hp
Old 02-13-2017, 10:46 PM
SwedeInSiam
Have you checked you checked the fuel pressures?
That's were I would start.
Old 02-13-2017, 10:47 PM
GerritD
GerritD's Avatar
same thought just crossed my mind. I suspect my fuel pressure has become ( it worked before though) too high.
Old 02-13-2017, 10:53 PM
SwedeInSiam
High control pressure will give a Lean mixture.
Low control pressure will give a Rich mixture.
Cold start valve could be stuck open either by a faulty valve or the wrong electric connector put on it.
Old 02-13-2017, 11:00 PM
GerritD
GerritD's Avatar
There is one item I perhaps have to check since exhaust is smoking alot : stuck fuel return line.
Old 02-14-2017, 01:44 PM
GerritD
GerritD's Avatar
I found my problem : the rotor in the distributor was misaligned ! When piston 1 is in top position, rotor should point to mark on the distribution at spark connection to cilinder 1.
Very strange as I am sure to have put it at the correct position
I now tried to start but no luck, no start at all, I even had backfire in exhaust and throttle house
Old 02-14-2017, 08:29 PM
GlenL
GlenL's Avatar
The important part is to have spark plug wire for #1 above the rotor when the cams are at their notches.
Then make sure the wires are in order. I traditionally mess up 5&6.
Quick Reply: 928S euro hard start and no running
