928 Forum 1978-1995
Sponsored by: 928 Specialists
No Heater and runs hot at idle.
Old 02-13-2017, 08:10 PM
  #46
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Originally Posted by Mongo
Jim, in my case, it is low speed/low load. anything under 35 mph and that gauge is at the top white mark. Smack the dash pod, and it drops down a tad to around the middle. It also jiggles like crazy after that.
I had that too.
Then I cleaned the pod contacts.
Old 02-13-2017, 08:50 PM
  #47
Jim M.
Jim M.'s Avatar
In that case I think you have two problems, a bad gauge (connection or bad grounds) and a water flow problem causing the no heat issue.
Old 02-13-2017, 10:11 PM
  #48
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,072 Likes on 1,183 Posts
Originally Posted by safulop
You realize that thing where Fonzie got the jukebox playing was just a TV show right? It didn't really work that way.
Originally Posted by Speedtoys
I had that too.
My 87 too. The needle doesn't move until I smack the pod then it works fine until the next startup.
It's on the list.......
Old 02-14-2017, 01:27 PM
  #49
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
I had the pod off and cluster out before to fix an odometer issue. When it was out, I cleaned the little "football" contacts that plug into the back of the gauges. The instruments worked great after that!
It couldn't hurt to go back in and do it again of course. My only fault from the last time was the lack of Deoxit. I suppose I can also rub a little bit of Deoxit on the contacts where the cables from the wiring harness connect to the circuit foil without any detrimental effects?
Old 02-14-2017, 01:47 PM
  #50
SeanR
SeanR's Avatar
Buy a new one and you won't have any more issues. I know it's easy to say but you know that the price will never be cheaper than it is today.
Old 02-14-2017, 01:50 PM
  #51
Mongo
Fuse 24 Assassin
Mongo's Avatar
Gauge? They are still being made?! :wow:
I was tempted to pick up a new circuit foil too.
Old 02-14-2017, 02:09 PM
  #52
SeanR
SeanR's Avatar
No, the circuit foil.
Old 02-14-2017, 02:58 PM
  #53
Speedtoys
Speedtoys's Avatar
Ya...mine used to move up a lot, then bounce down...
Lots of pod issues went away with deoxit and cleaning. Esp how DIRTY the bulbs were. OMG.
Old 02-14-2017, 03:05 PM
  #54
Mongo
Fuse 24 Assassin
Mongo's Avatar
Jeff exactly what parts did you clean to fix it? I may tear into it tomorrow night after I find a source in SF for Deoxit on the way home.
Just want to confirm what to clean again. I know Dwayne did a great write up a while back on this.
Old 02-14-2017, 03:21 PM
  #55
hacker-pschorr
I'm waiting until I decide on what to do with the dash, once that is in the works I'll start taking apart the pod / dash to go through everything.
Old 02-15-2017, 07:04 PM
  #56
Mongo
Fuse 24 Assassin
Mongo's Avatar
It dawned on me to post a picture I took of the Laso water pump I installed on my car almost 4 years ago:
Again, this pump has less than 1,500 miles on it. I THINK the brown impeller is the new design pump that is less prone to failure. I also see some sort of bushing in between the shaft and the plastic impeller. Has anyone had a failure with this new style yet?
I'm still weighing a 'worse case scenario here'. I have a porken tensioner on mine so I don't need that extra shaft the other S4s do running the OE belt tensioner. OB pump will work fine. Looks like the GEBA is still my only option for a pump replacement.
Old 02-15-2017, 07:45 PM
  #57
dr bob
Chronic Tool Dropper
dr bob's Avatar
Didja change the thermostat and the seals yet? It seams like you are torturing yourself over a lot of absolutely worst-case scenarios when it's quite likely the thermostat is sticking from not being exercised. Cheap. Easy. Likely. The old one is bypassing a lot of coolant around the radiator, and in the process not enough pressure drop through the HCV and heater core or radiator to cause flow. Until the pump is spinning faster and more flow is bypassing, then you get some pressure drop through the heater circuit and radiator, some flow, and some heat in the cabin. What's not to love about changing the thermostat as a first step? Cross it off your list with a new one and less than 30 mins of wrench time. Including clean-up. Nickel to a dollar (my nickel...) says this will take care of you.
Old 02-15-2017, 10:21 PM
  #58
Mongo
Fuse 24 Assassin
Mongo's Avatar
That is very encouraging. Thanks
Old 02-16-2017, 11:47 AM
  #59
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,251 Likes on 1,245 Posts
Andy, also swap out the heater control valve the short hose and the coolant bottle cap if they are older than 5 years.
On the thermostat make sure to replace the rear seal as well,
this part causes a lot of cooling issues
Old 02-16-2017, 01:38 PM
  #60
Mongo
Fuse 24 Assassin
Mongo's Avatar
The thermostat and seals are supposed to come in today. I ordered the inner seal that sits behind the thermostat in the order. I will be diving into it this weekend. The wife and I will be doing a brake bleed and pad swap tonight.
Quick Reply: No Heater and runs hot at idle.
