Failed upper and lower engine cradle seal post-mortem - Page 3 - Rennlist Discussion Forums
Thread Tools Search this Thread
Old 03-16-2017, 01:01 PM   #31
Hacker-Pschorr
Super Moderator - Cracklin' Rosie
Hacker-Pschorr's Avatar
Quote:
Originally Posted by GregBBRD View Post
Never, never , never touch aluminum surfaces with one of those "Rotary Scotch-Brite pads....regardless of which one looks like it will work! I don't care what your buddy the "professional mechanic" does when working on a Toyota at his shop! Never try to use any power tool!!!
It's a lot of fun putting two case halves together and being able to see daylight through parts after some monkey used a rotary wheel to clean the surface.
Hacker-Pschorr is offline   Reply With Quote
Old 03-16-2017, 01:08 PM   #32
Kevin in Atlanta
^^^ yeah, basically except for the throwing up blood.
I have learned a lot along the way.
Used some gasket remover on the lower cradle:
Results after waiting 10 minutes. (Should have waited longer per the instructions. 15-25 minutes for anaerobic ) And it is damn cold.
Before:
Kevin in Atlanta is offline   Reply With Quote
Old 03-16-2017, 01:20 PM   #33
davek9
davek9's Avatar
Kevin if it's the 3/8" it does 35 ft lbs, the 1/4" does 30 ft lbs.
"...I have milwaukee right angle electric ratchet. I think it torques to 12-14 ft lbs. I'll double check that. ...".
I love that 3/8", it's my go everywhere tool
Dave
davek9 is offline   Reply With Quote
Old 03-16-2017, 02:06 PM   #34
Imo000
Captain Obvious
Super User
Imo000's Avatar
That gasket removed is an excellent carbon remover too. If the pistons or the combustion chamber has excessive carbon, this is the product to use. Let is sit for 5-10 min and the carbon will wipe off, even the really thick ones.
Imo000 is offline   Reply With Quote
Old 03-16-2017, 02:08 PM   #35
davek9
davek9's Avatar
Quote:
Originally Posted by Imo000 View Post
That gasket removed is an excellent carbon remover too. If the pistons or the combustion chamber has excessive carbon, this is the product to use. Let is sit for 5-10 min and the carbon will wipe off, even the really think ones.
Great to know, thank you
Old 03-16-2017, 02:13 PM   #36
Imo000
Captain Obvious
Super User
Imo000's Avatar
Quote:
To keep the rings intact from this product, tilt the block so that the gasket maker leaks out of the cylinders and doesn't go down to the rings. Discovered this by accident when was trying to clean up the gasket material on my 996 engine. It truly is amazing how well it works. Others on RL have since used it for the same purpose and got the same results.
Old 03-16-2017, 02:18 PM   #37
Kevin in Atlanta
^^^ The block was cleaned with just razors.
Gasket remover is for the lower girdle. I will keep it away from the bearings.
Old 03-16-2017, 02:39 PM   #38
Chris Lockhart
Chris Lockhart's Avatar
It's dang expensive for how much product you actually get, but it works like no other product I could find. Absolutely fantastic. This was the ONLY product that I tried that would clean the carbon on both the piston dishes and the combustion chambers in the heads. I bet I spent $100+ $$$$$ on just this product. Not to mention the wasted $$$ on the products that didn't work.
Chris Lockhart is offline   Reply With Quote
Old 03-16-2017, 02:41 PM   #39
SeanR
Running up the Odo'
SeanR's Avatar
Dave
I've been looking at those, which one do you have?
SeanR is offline   Reply With Quote
Old 03-16-2017, 03:06 PM   #40
davek9
davek9's Avatar
Sean I have this one, I purchased it way ove a year ago and paid 100 bucks (home depot IIRC)
I see them listed now for $89.00 not sure if that includes the soft case and charger, mine did.
The 1/4" version was not on sale, it was still around 100.00.
Soft case is useless IMO, I just lock it and toss it in my portable tool bag, else it sits on my bench
https://www.milwaukeetool.com/power-...rdless/2457-21
Old 03-16-2017, 03:10 PM   #41
SeanR
Running up the Odo'
SeanR's Avatar
Thanks, I'll check that one out.
Old 03-16-2017, 03:46 PM   #42
Kevin in Atlanta
Sean I have this one, I purchased it way over a year ago and paid 100 bucks (home depot IIRC)
That is what I use. Also, have a right angle drill from same vendor. My son turned me onto them. Good quality.
Old 03-17-2017, 12:28 AM   #43
GregBBRD
Small Business Partner
GregBBRD's Avatar
I've got to get someone to send me some of this stuff. Here in Kalifornia, they have taken away anything stronger than water.
GregBBRD is offline   Reply With Quote
Old 03-17-2017, 01:43 AM   #44
Dave928S
Dave928S's Avatar
^^ I've found the loctite gasket remover also works well on hard to remove carbon.
Dave928S is offline   Reply With Quote
Old 03-19-2017, 07:11 PM   #45
Kevin in Atlanta
Well Kevin Wilson and I assembled the block today.
Here's what the loctite application looked like before we placed the lower cradle into place:
Following Greg's instructions religiously we saw some of the loctite weep along the two mating surfaces
Related Topics
Thread Thread Starter Forum Replies Last Post
BBS E88 Custom Wheel Build BUTZI996TT 964 Forum 18 03-18-2017 06:33 PM
FS: 944 S intake w/ throttle body & idle solenoid Noahs944 924/931/944/951/968 Forum 0 01-14-2017 03:04 PM
Stripped Lower Girdle Hole Kevin in Atlanta 928 Forum 18 05-15-2016 11:05 AM
lower half of side view mirror- matte or shiny? knfeparty Porsche Cayenne Forum 2 08-02-2015 08:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ę 1998 - 2015 Rennlist.com
