928 Forum 1978-1995
Sponsored by: 928 Specialists
Porsche tool 9165 (bearing dustcap removal)
Old 01-10-2017, 09:57 PM
Bucko74
Bucko74's Avatar
Default Porsche tool 9165 (bearing dustcap removal)
Hi All,
Anyone know where I can purchase one of these tools. Seems like its the best way to remove front hub dust cap without destroying it.
Alternatively a method to remove the cap without damage would be fine.
Old 01-10-2017, 10:05 PM
G.P.
G.P.'s Avatar
Posts 361 to 367 in Highwayman's thread may help.
https://rennlist.com/forums/928-foru...e-dead-25.html
Old 01-10-2017, 10:18 PM
Bucko74
Bucko74's Avatar
Cheers, will definitely do the mod. I've just seen the other method using exhaust clamps which seems like it should do the trick.
Only reference to the tool suggests I've found suggests its not worth chasing.
1) its expensive for one single application
2) difficult to find.
Old 01-11-2017, 10:07 AM
kmascotto
kmascotto's Avatar
...I wondered what that tool looked like...
Old 01-11-2017, 11:46 AM
StratfordShark
StratfordShark's Avatar
That seems like a sledgehammer to crack the dust cap nut!
What I found worked well was a short extension for 3/8" sockets. The ball end fits nicely in the groove running round front of dust cap. Pick or mark three points 120deg apart roughly around this groove, and go round the points with the extension inserted facing away from car, and tapping end with a hammer. Will soon loosen the cap and not cause any deformation.
Old 01-11-2017, 12:24 PM
FredR
FredR's Avatar
I just pry the thing out a little at a time working around the circumference using a wood chisel- worked a treat for me a good number of times when I was changing the set of wheels I was using- my 3 piece ones do not fit over the caps but the flange seals the base and the centre cap keeps the grease in just fine when sealed with RTV.
Rgds
Fred
Old 01-11-2017, 12:51 PM
ROG100
Basic Sponsor
ROG100's Avatar
Part number is 000 721 916 50 and NLA. Price was $94.
Old 01-11-2017, 02:21 PM
Ad0911
Ad0911's Avatar
Oops, I always removed them by tapping with a hammer along the edge direction outward while turning the wheel. Never realised there eas a tool for this. It'll take some tapping but no harm done
Old 01-11-2017, 06:18 PM
The Forgotten On
The Forgotten On's Avatar
You can use a large metal pipe end cap from home depot to emulate this tool.
Drill and tap 3 holes around it like the factory tool. Drill and tap a hole on top for a slide hammer and you could replicate this tool for not much money, just some of your time.
There was a thread on this somewhere as the real tool is a bit pricey for a tool that may get used 4 or 5 times.
Old 01-11-2017, 10:56 PM
Bucko74
Bucko74's Avatar
This worked a treat.
Old 01-11-2017, 11:09 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
The times I've needed to remove the cap, a handy short section (maybe 8" or so) of oak hardwood flooring indexes in the relief, then a few gentle pops with a hammer progressively around the cap. The wood leaves no telltale scarring like the various metal tools do. Including the factory piece. If you want the cap to appear original and unmolested, the stick of wood is perfect.
Old 01-12-2017, 12:42 AM
The Forgotten On
I have used a dull head off of an ax before to do this. It seems to work just fine
Old 01-12-2017, 07:28 PM
jpitman2
jpitman2's Avatar
Using a screwdriver shaft (similar size to that in pic above) placed horizontally in the groove between cap and hub, tap on the shaft with hammer, working around the hub by turning the wheel, the cap will ease out readily.
jp 83 Euro S AT 57k
Quick Reply: Porsche tool 9165 (bearing dustcap removal)
