Temp gauge spike
Temp gauge spike
Hey guys, so my temp gauge likes to work when it feels like it. Most times though it just spikes all the way up when I start the car which usually indicates a ground issue. I've had the pod out three times now and cannot find an issue with the pcb or connections to it. Also checked the sender and swapped with a known good one, same problem. Any idea where to look now?
I have the same problem on one of the '86.5's. What I have found is my 'tab' release arm is broken. If I reach under and push (just slightly) the gauge works correct. Check both the ribbon end and cluster ends. Hope this helps.
