928 Forum 1978-1995
Sponsored by: 928 Specialists
Single disk clutch disk better than 2?
Old 08-30-2016, 07:38 PM
vanster
vanster's Avatar
Default Single disk clutch disk better than 2?
The later 5sp cars had single clutch disk. My '80 was converted using an S4 flywheel. I have no idea what the clutch is like in my red car and now wondering if I should switch to a single using the parts from my 85 parts car.
Old 08-30-2016, 08:49 PM
jcorenman
jcorenman's Avatar
Van, the '85 (and the red car) should be twin disk, the single started in '87. Lots of folks have swapped both ways, so you will have to look. The twin has a lighter pedal, longer travel, holds more torque and can be fiddly to adjust.
Old 08-30-2016, 09:18 PM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,451 Likes on 1,459 Posts
And I just installed new discs.....
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
Old 08-30-2016, 11:45 PM
vanster
vanster's Avatar
The 85 parts car has an S4 motor so I assume that it has a single disk. The clutch in my 86 is very light. Just curious why the change was made. I had assumed it was easier for the dealers to service and of course there were fewer and fewer manual's.
Old 08-31-2016, 12:28 AM
The Forgotten On
The Forgotten On's Avatar
They could have kept the dual disk if it was working in your parts car. Only way to find out is to drop the lower bell housing and have a look.
Old 08-31-2016, 02:32 PM
mark kibort
mark kibort's Avatar
i used and swapped out the single disc to a dual disc because it holds more torque AND is 20lbs lighter and thats rotating mass, so its effect is very noticeable when quick reving the car.... and a possibly in 1st gear where acceleration rates are high and it has more of an effect.
Old 08-31-2016, 06:27 PM
crushingday
crushingday's Avatar
Can one put the dual disc in an early '78 US car? is it recommended?
Old 08-31-2016, 06:29 PM
James Bailey
James Bailey's Avatar
already has it.....
Old 08-31-2016, 06:50 PM
crushingday
Originally Posted by James Bailey
already has it.....
Well then!...their ya' have it.
Old 08-31-2016, 07:42 PM
mark kibort
yes you do!!!
i dont know the differences , Jim does, but the early and later cars have slightly different components. but generally they work the same.
Quick Reply: Single disk clutch disk better than 2?
