Are stop light switch connectors available? 78 euro.
... without replacing the wiring harness...
One brittle little wire broke while changing the master cylinder. The connectors are not in great shape so I am willing to change them if they are available and can be easily patched in.
Thanks.
Thanks.
Chronic Tool Dropper
The early pressure switches have fairly standard 1/4" spade lugs. There are single-conductor crimp connectors available for repair.
I suspect that the three-tab layout of the switch connections is very close to an H4 headlight bulb connector. Might be worth a test-fit, as H4 repair connectors are readily available.
