928 Forum 1978-1995
Sponsored by: 928 Specialists
What oil do you use and why?
Old 08-27-2016, 03:59 PM
Red Flash
Red Flash's Avatar
Good idea!
Amsoil 20W-50 Zrod because:
1.) Carries good oil pressure even if very hot weather 100°F
2.) Has Zinc/ZDDP in appropriate amount
3.) Supposedly provides long-term, internal protection from corrosion if in storage (if you don't drive your 928 all year.)
4.) My chief 928 mentor did not say anything bad about it
https://www.amsoil.com/shop/by-produ...ont%2fzrf.aspx
Cheers to all, John
Old 08-27-2016, 04:05 PM
zekgb
zekgb's Avatar
Brad Penn 20w-50 cause Greg Brown likes it ldo. Plus it's green and smells like mint.
Old 08-27-2016, 04:15 PM
Randy V
Randy V's Avatar
Only heavy weight synthetic oil should be used in the 928 engine.
No telling what I'm using in mine.
Old 08-27-2016, 04:51 PM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,452 Likes on 1,459 Posts
^^^^^^^I've got Randy's engine apart, at 240,000 miles. Randy drives it like he stole it.^^^^^^^
The rod bearings look like they got changed 2 months ago and the cams look fantastic (which is extrememly rare for a GTS engine.)
Whatever he has been doing is working!
I'm currently using Brad Penn 20/50 in customer cars.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
Old 08-27-2016, 04:53 PM
Brent
Brent's Avatar
God help me for posting to this thread.
Royal Purple 20W-50.
Changed from Mobile 1
Why? Love the color. Better pressure in hotter weather, heavy stop and go traffic. Love the color. Doesn't use any oil between changes, Mobile 1, had to add a quart every 1000 to1500 miles. Love the color.
Regards,
Old 08-27-2016, 05:06 PM
bureau13
bureau13's Avatar
Royal Purple HPS 20w50
- Purple
- Appropriate zinc content
- I was a fan in my rotary days (I was on the "Mazda is wrong to recommend against synthetic in turbo rotaries" side of that discussion)
- I can get a case from Amazon pretty easily and pretty reasonably priced
- I saw a few folks on RL had had good results with it
Old 08-27-2016, 05:37 PM
ROG100
Basic Sponsor
ROG100's Avatar
3-in-one sewing machine oil.
Allows my engine to rev faster.
Much better miles per gallon.
Cheap to buy at Wally World.
Comes in small handy cans that I can keep in the glove box.
Super nice gold color.
No zinc so my bearings wear really fast.
Makes the guys at Blackstone labs mad.
I can also use it to lubricate the teeth on my paper shredder.
Because Greg does NOT recommend it.
Comes in handy if you run out of KY.
Not made by Amsoil
Old 08-27-2016, 07:00 PM
Fogey1
Fogey1's Avatar
Originally Posted by BIMMERMIKE
Going to Frenzy in September and want to buy some of this oil!!
Here in Canada this oil is crazy expensive!
When returning from SITM June 2016, I stopped at a Walmart close to Pittsburgh and no stock. Hope to get a few jugs when returning from Frenzy.
Any recommendations/suggestions?
Stop at more Walmarts until you find one with stock, and stock up.
You could probably call ahead to Walmarts along your route.
Old 08-27-2016, 07:17 PM
jej3
jej3's Avatar
Mobil 1 15w50 because of the ease of accessibility and ease on the wallet at Walmart. I also generally add Rislone to boost ZDDP (because it makes me feel good )
Old 08-27-2016, 07:32 PM
JWise
JWise's Avatar
I've always used synthetics in the recommended weight, either 15w-50 Mobil 1 (high ZDDP) or 20w-50 Torco SR-1 (high ZDDP and 'cause Greg said so!)
Also, as Dr. Bob mentioned, synthetics have superior cleaning ability. In less than 20k miles, my engine internals went from yellow/orange tinted to looking like new.
Old 08-27-2016, 09:54 PM
MainePorsche
MainePorsche's Avatar
I use exactly the same. I add a half bottle of the zinc concentrate to every change. My engine has run very well for 9 years. I wouldn't think to change the formula.
Old 08-27-2016, 11:22 PM
928 at last
928 at last's Avatar
Brad Penn 20 / 50
Read waaayy to much about oils a few years back, and this one seemed to fit the bill, particularly on the ZDDP levels.
I understand Greg likes it too....
And it's green. And it says "Racing" on the container...has to make the car go faster....
Old 08-27-2016, 11:26 PM
928 at last
Oh, and Amsoil gave me a cardiac several years back when a friend suggested it for my snowmobile, and on a cold morning I thought my engine seized. I'm not a small guy, but that sucker wasn't moving until I hairdryered it for a couple hours. So...maybe a little too thick.
Sled was fine after going back to the Arctic Cat house brand.
But I digress.
Old 08-27-2016, 11:36 PM
curtisr
curtisr's Avatar
Can't believe I'm the only one but here goes...
Rotella 15W40 Triple Protection (T3) because:
  • it was recommended by other owners
  • usually on sale somewhere
  • meets SM requirements and features ~ 1200 ppm of zinc and 1100 ppm phosphorus, and
  • reward code under the cap
Old 08-27-2016, 11:44 PM
SwedeInSiam
SwedeInSiam's Avatar
Castrol GTX 20w50 with STP Oil Treatment added for ZDDP content.
Reason because we don't have much choice in 20w50 oil for gasoline engines here. Plenty available for diesel trucks in 20w50 but don't like to use that.
Quick Reply: What oil do you use and why?
