928 Forum 1978-1995
Sponsored by: 928 Specialists
Foglights connector....
Old 08-25-2016, 03:09 AM
Pboden
Pboden's Avatar
Default Foglights connector....
My recent acquired foglights for my -87 had no connectors. It was stripped so I either need to strip the corresponding wire or preferably find a fitting connector.
Searched the web with no luck.
Anyone know if these connectors are available ?
Old 08-25-2016, 10:56 AM
jcorenman
jcorenman's Avatar
The connectors and cable are usually part of the back housing, which mounts to the bumper. Did you get the whole assembly-- lens, reflectors and back housing-- or only the front part?
The cable is maybe half a meter long, with slip-on spade connectors at the light end (to connect directly to the H3 lamps), and a three-pin "Surseal" rubber plug at the other end to plug into the car harness.
Porsche only sells the complete assembly (or the lens/reflector), not the back housing or cable separately. The best option is probably to find a local breaker or used parts source. (The cable is wired differently for US and ROW cars-- the fog and driving lights are reversed in position for the US-spec cars).
Old 08-26-2016, 02:27 AM
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
We should have a few fog light harnesses but I'm not sure USA are the same
Old 08-26-2016, 11:54 AM
jcorenman
jcorenman's Avatar
The fog and driving lights are reversed for USA-spec versus Euro, so all you need to do is swap two pins in the rubber 3-pin connector that connects to the car harness.
Old 08-26-2016, 05:00 PM
jorj7
jorj7's Avatar
Pboden,
When you say fog lights, do you mean the fog light lens and bulb enclosures? Like this:
or the box that this mounts in on the bumper:
George
90 S4 Grand Prix White (Murf #5)
94 GTS 5-Speed Midnight Blue
06 Cayenne S Havanna/Sand Beige (PASM)
http://928.jorj7.com
Old 08-26-2016, 06:15 PM
Pboden
Pboden's Avatar
I mean the three pin rubber connector that connected to the foglight.
I was actually thinking about using a 9003 connector on both ends instead.
Old 08-29-2016, 12:27 PM
Pboden
Pboden's Avatar
Assistant please....
Have started to hardwire the wires going to the foglight, but Iam probably not doing it right. I get voltage reading from one wire (Grayish). The other three is one brown(ground) and two are white with one red and one green stripe. Which wire go where ?
I would appreciate if somebody could supply a picture of how the wires should be connected inside the foglight.
Quick Reply: Foglights connector....
