928 Forum 1978-1995
Sponsored by: 928 Specialists
No compression in #2 after belt change
Old 08-04-2016, 06:58 PM
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
Default No compression in #2 after belt change
So we shipped a used engine and the customer is saying that there is 0 compression in cylinder #2. They did replace the belt and water pump before installation. We do compression tests on all motors before shipping so it was good when we shipped it. My one thought was did the mechanic take the belt off at TDC instead of 45 and would the cams moved enough to tag some valves. We asked them to spray WD40 in the hole and check again and still 0. All other cylinders have reasonable compression.
The motor is S4
Any other ideas or possibilities?
BTW the car is in Yorktown Heights NY
Old 08-04-2016, 07:04 PM
James Bailey
James Bailey's Avatar
What else did they do ?? intake removal /refresh ?
Old 08-04-2016, 07:14 PM
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
Valves. Someone missed the memo about the 45 degree mark.
Old 08-04-2016, 07:23 PM
Mark Anderson
The Parts Whisperer
they did take the intake manifold off
Old 08-04-2016, 07:24 PM
Mark Anderson
The Parts Whisperer
that was a guess of mine but I don't know if that would do it. I was hoping someone might chime in that it happened to them and yes it was #2 that bent valves
Old 08-04-2016, 07:59 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Have them put a scope down the #2 and see if all looks normal. There could be something stuck between the valve and the seat.
Old 08-04-2016, 08:03 PM
Mark Anderson
The Parts Whisperer
do any bore scopes look back?
we first thought maybe some carbon under the valve but after running it a bit I would have thought it would clear up
Old 08-04-2016, 08:42 PM
Mongo
Fuse 24 Assassin
Mongo's Avatar
Ah, Imo has a good point. If you're removing the intake, there is bound to drop some remnants of an old gasket into the intake ports. One of the first things I did when I did my intake back in 2009 was take a vacuum cleaner to all intake ports where the valve was closed after having a peak down it. Anything else that dropped past the valve and into the chamber I prayed would not fowl up the exhaust..... and yes there was lots of Permatex orange used by the previous owner's mechanic, Julio.
Old 08-04-2016, 09:48 PM
Dave928S
Dave928S's Avatar
My first thought was also something dropping down an intake and getting between a valve and seat. If there had been a timing/valve event you'd think it would be more than one valve.
I have a German made optical borescope that has a very wide field of view, has a super bright halogen light, looks at 90 degrees to the 8mm shaft, and can see all the chamber and valves ... but I'm a bit far away to lend it to anyone in the US
I do have a couple of cheaper video borescopes which have small mirror attachments which allow you to look back to a reasonable degree, and I'm sure they would also do the job, but the clarity isn't as good.
Hopefully it's only a bit of gasket and not metal.
Old 08-05-2016, 12:13 AM
Herman K
Herman K's Avatar
Default Yes
0-180 degrees
http://www.ebay.com/itm/301915679388?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old 08-05-2016, 12:53 AM
Dave928S
Dave928S's Avatar
^^^ Wow, that's neat! I think I'll order one.
Old 08-05-2016, 01:44 AM
hlee96
hlee96's Avatar
You mean like this?
Old 08-05-2016, 02:00 AM
granprixweiss928
granprixweiss928's Avatar
I have the cheap harbor Freight scope and it comes with a little clip on 45deg mirror for the end sp u can see the sides, which means valves too as soon as its thru the plug hole. Remove the mirror and it looks straight down at the piston top
Old 08-05-2016, 01:40 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Mark-
Easiest way to find the cylinder leak is by putting the suspect cylinder at TDC and putting a little compressed air in through the plug hole. They will be able to hear any air escaping. Doesn't take a lot of air volume, and depending on the fitting used on the plug hole less can be better. I have an old "bargain" compression gauge that uses a short hose with a air-line disconnect for the gauge. A mating disconnect on a regulator lets me put as much or as little air in there as needed. Point is though that it's an easy way to connect air to the cylinder for any pressure or leak testing.
Old 08-05-2016, 03:02 PM
Mark Anderson
The Parts Whisperer
Originally Posted by dr bob
Mark-
The mechanic seems to have limited abilities but I will ask.
Quick Reply: No compression in #2 after belt change
