Groaning power steering pump fixed with Rennbay kit
I thought I'd mention that the Rennbay power steering pump reseal kit fixed the groaning/buzzing power steering in my supercharged 928S4, which I actually worked on today despite having a half measure of Old Pulteney after work.
I'd tried flushing the fluid, tried replacing the reservoir, to no avail. I was not sure the noise, cavitation noise probably, would be fixed with a pump reseal but it must have had an internal fluid leak or something that was causing that groan because it's fixed.
-Joel
-Joel
Me too, it was not clear to me that the pump reseal would fix the groaning and foaming fluid and I was worried I'd need a steering rack. It was a pretty easy job, but I was also doing the timing belt / water pump and rebuilding the alternator (bearings were naaasty).
