928 Forum 1978-1995
Sponsored by: 928 Specialists
New ignition wires
Old 07-29-2016, 09:53 PM
Dark Blue
Dark Blue's Avatar
Default New ignition wires
Any tips or tricks on installing new ignition wires. I just got my new Beru's from Roger. Thanks,
Steve
'89 S4
Old 07-29-2016, 10:13 PM
Rocinante
Rocinante's Avatar
I thought I read elsewhere on this forum that he includes a set of installation instructions. IIRC, someone had posted these instructions in a thread.
Old 07-29-2016, 10:21 PM
rbrtmchl
rbrtmchl's Avatar
Here is a good thread to refer to:
https://rennlist.com/forums/928-foru...r-dummies.html
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,541 Likes on 1,228 Posts
Take the old ones off, transfer the plastic wire brackets from old to new, reinstall. Here's the orientation:
Old 07-30-2016, 01:03 PM
jheis
jheis's Avatar
I went one step further than Rob ^
I numbered both ends of each lead with a P-touch label maker and then wrapped the numbers with Locktite clear self-fusing tape. Also numbered each position on the distributor caps with the P-touch. Well worth the extra time.
It takes a lot of plugging and unplugging when you are trying to get the wires routed just right and it's much easier when you can just match up the numbers.
Quick Reply: New ignition wires
