Tires - Again
Tires - Again
Friends,
I've got some 16" rims on my '89 S4 and am having a hard time finding the correct tires. Toyo makes them but Tire Rack says they're not currently available.
On my last S4 I ended up compromising and ended up with a huge tractor tire on the rear which always bothered me.
Who's got a lead on the correct tires.
Thanks, Josh
Thanks, Josh
You are best off actually calling Tire rack and inquiring. The website is often inaccurate about inventory in these tire sizes.
Thank you Glen !
OK lemme ask - how does it look? Can't look worse than the big *** tire I put on my last 928.
Anyone else running this set up? Common solution?
Josh
Josh
IMHO I don't like it. PO on my car bought S4 rear wheels, put the smaller tires on it ("because he couldn't find a matching set"). I don't like how it looks. The tire sits behind the rim, so it's very obvious that the tire is too small.
Thankfully the owner gave me the original rears which I'm going to put back on.
A couple of weeks ago I ordered Toyos in the correct size from Tire Rack for my '88. Then they called me to say they could not get them for an indeterminate time, so they cancelled my order. They also could not get the Bridgestone RE11 that I got from them a couple of years ago for my '90 either. Several other suppliers listed the Bridgestone, but then could not supply.
In the end I went with 245/50 vs the 245/45 specified. Much more choice and a barely visible difference IMO. The circumference is only +3.3%.
I run this on a set of S4 wheels. They look good. Only you will know there could be a larger tire. It's just 20mm, after all.
Check the detailed specs for the tires and you'll see the wheel sizes the mfg suggests.When I look, 7" is on the smaller end for a 225/50/16 tire. Tire Rack is good for that.
Check this link to Porsche's announcement back in 03/2016
https://newsroom.porsche.com/en/hist...hrl-12463.html
Anyhow, the release for N certified tires in the correct sizing for the 928 is listed on
http://www.porsche.com/germany/acces.../tyreapproval/
Tires/Vendors are:
Continental ContiSportContact
Pirelli P Zero Nero
Pirelli P Zero Trofeo R
You can probably get them ordered through the Porsche dealer.
Tires/Vendors are:
Pirelli P Zero Nero
Apparently I bought the last Toyo T1R 225/50/16 in Australia yesterday, and was told the T1R is no longer available.
Hope this is not going to become a issue - but am beginning to look through the "cool wheels" threat.
Tires
I'm on my 6th set of Bridgestone RE-11's Great tires! Now comes in all sizes 16" for my GT.
Administrator - "Tyson"
1. Call on the Toyo's, I'm sure the lack of inventory is temporary
2. Ask about the RE-11's, might be coming back
3. Look into the Porsche classic tires (that is what I would do)
4. Buy different wheels (actually that is what I did)
A lot of options before reducing to 225's out back on an S4, something I would never do.
I've got 255's on the back of my 80 mounted on modified phone dials.
EDIT - I totally forgot what the issue is with the Bridgestone RE-11. The fronts are V rated while the rears are W so when you do a search under the car they don't pop up. This is baffling why there is a difference and I cannot imagine there would be any issues running them.
245/45-16 are listed as in stock:
http://www.tirerack.com/tires/tires....omCompare1=yes
Along with the 225's:
http://www.tirerack.com/tires/tires....11V2&tab=Specs
I'm looking forward to the pricing on those Dealer-supplied, special-order tires.
I get the heretical "reduced" (lol) tires from the local tire stores (more heresy!) and save money by getting them to price-match and cut installation costs. I like these: Continental ControlContact Sport AS
Tire rack tires I believe generally have fairly new date codes of manufacture. If you are buying new tires from a local source I'd ask about or check the date code of manufacture just to make sure that you are not buying (old) new tires.
'89 928 S4 GP White/Black
