928 Forum 1978-1995
Sponsored by: 928 Specialists
Aluminum Floor Jack for a 928 - $99
Old 07-26-2016, 03:18 PM
Bilal928S4
Bilal928S4's Avatar
Default Aluminum Floor Jack for a 928 - $99
I was at Costco and saw this jack. Seems to be well built and at a very reasonable price. Hope you guys take advantage of it before somebody alerts the mods to delete the post.
http://www.costco.com/3-Ton-Professi...100222458.html
Old 07-26-2016, 05:08 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
I have exactly that same 3T roller jack, but with a "Craftsman" label on it. Has done the garage duty for close to ten years. In fairness, the last more-than-several years have seen duty shared by the Max-Jax lift. When we rolled the jack out a a month ago to put pressure on Jim C's '78 front suspension, it worked as expected.
I particularly like the big rubber pad in the lift shoe, saves the jack points on this car, and also when lifting other cars by other places. No mar of suspension points when used for assembly etc.
It is barely low enough to get under the rear lift loop on a Lotus 46, OK under a 23.
Bottom line, this is a good choice if you need a 928 garage jack.
Old 07-26-2016, 06:06 PM
77tony
77tony's Avatar
That Cosco jack will fit under the 928 but not the 991. This one will and it's only $ 75.93 with free shipping:http://www.ebay.com/itm/like/2317349...&ul_noapp=true
Old 07-26-2016, 06:56 PM
buccicone
buccicone's Avatar
Looks like a Harbor Freight
Old 07-26-2016, 07:23 PM
Lopez
Lopez's Avatar
Agreed -
On the subject of Harbor Freight jacks, the smallest version of one the pictured (the low-profile unit that typically sells for ~$70) couldn't lift my '79 928's (stock ride height) body off high enough to get the wheels off the ground. It's the only jack that fits under my Caterham but it proved pretty useless for the Porsche.
Old 07-26-2016, 07:50 PM
Rocinante
Rocinante's Avatar
On what basis would a moderator delete this post?
Old 07-26-2016, 08:10 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,069 Likes on 1,181 Posts
The extra long low profile jacks are the best for a 928, easily reaches under the front and rear cross members:
http://www.harborfreight.com/2-ton-l...ump-68050.html
http://www.northerntool.com/shop/too...4333_200514333
https://www.amazon.com/Advanced-Desi.../dp/B000OUZVK0
Yes they are heavy, but unless you have to pick up your jack a lot, weight isn't an issue.
Old 07-26-2016, 08:21 PM
Rocinante
Rocinante's Avatar
IMHO, if you are going for HF, you can get a 3 ton low profile jack for less than 90 bucks. I picked one up to use on my wife's DD (2000 Celica GT-S) earlier this spring, and I've got no complaints.
Old 07-26-2016, 08:31 PM
hacker-pschorr
The 2 1/2 ton is lower and longer which can be a big factor getting under the front cross member on cars with a front spoiler:
Old 07-26-2016, 08:39 PM
Rocinante
Rocinante's Avatar
Thanks - a picture is a thousand words.
I might have a 3 ton jack for sale soon...barely used!
Old 07-27-2016, 12:45 AM
Richard S
Richard S's Avatar
Maximum lift height can also be a consideration. 18.6" for the Costco jack vs 23.75" for the 2-ton HF Hacker posted.
Sometimes you need a few extra inches.
Rich
Old 07-27-2016, 09:19 AM
V2Rocket
Rainman
V2Rocket's Avatar
OMG...
I have the all-steel ARCAN 3.5 ton long-reach jack for over 10 years...it is the heaviest thing in all the known universe.
Old 07-27-2016, 01:08 PM
dr bob
dr bob's Avatar
The originally-mentioned aluminum jack is the first non-steel jack I've owned. It replaced several roller jacks at once, including a very low-profile "bargain" that was used on the Lotii, a medium-reach 2.5T H-W that would reach the center section of the now-gone Explorer, and another 2.5T mini utility jack that was quite handy for under-car work. Rolf R, the previous owner of Sean (Safalup)'s S4, donated the aluminum jack to the clinic tool collection after we did a couple TB/WP jobs in one day. I think he felt sorry for me when he saw the ancient steel stuff languishing in the workbay.
The biggest advantage/confidence builder with the aluminum jack is how stable and rigid it is compared with the bargain steel jack. The H-W was plenty stiff, but the smaller low-profile steel jacks would twist and bind up if they weren't aligned to the car perfectly going up, and more importantly coming down.
Chris, for the lightweight LeGrand race car, I fabricated an aluminum cantilever jack that would fit under the front or rear suspension mount points, similar to the way F1 jacks used to work. Might be a thought for your featherweight Caterham. It was very stable, with about a 20" width, and picked the car nicely about 8" for tire changes or moving the car. For anything more serious on the LeGrand and its successors, three people could lift the car onto saw-horse supports. Or I'd grab the rollbar eye with the ceiling hoist and set it on them if I was by myself. Luxury bachelor times, with a couple thousand square feet of fab shop to play in.
Old 07-27-2016, 02:56 PM
Dan87951
Dan87951's Avatar
I love this jack. It had no problem even fitting under my DB9 when I had it.
Old 07-28-2016, 03:19 PM
mark kibort
mark kibort's Avatar
can you lift the car from the front cross member safely? (for the the car that is)
Quick Reply: Aluminum Floor Jack for a 928 - $99
