1979 928 metal fuel line flare
Basic Site Sponsor
Basic Site Sponsor
Muggyweld.com will get you the best silver solder I've ever used....
I haven't bought and tried Stan's induction heater tool (it took me a couple of hours to figure out what this thing's primary purpose was, not ever having to deal with cars from the East Coast)....but I'm going to.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Thanks to everyone for their help. Brian's pics helped a ton since I don't have a lift at home. I never realized that the clips on the 79 were different than the later cars. So much easier to work with the nylon as opposed to the later metal ones.
Greg, thanks again for the offer on the lines.
I decided to pull the line out of my parts 1981 and luckily, it used the same male 17mm fittings. The line itself it completely different at the back side, although in a pinch, I am sure I could have cut it and reworked the line. Instead, since it had a crush in it, I decided to just steal the fittings. I straightened the 79 line to allow the fitting to go far back enough to reflare. I then installed a new din/iso flare. I will then re bend the line to mimic the original bend. I lost 1/4 inch total of length, but I don't believe that will cause an issue.
I also believe I located NEW fittings and I have a sample being mailed to me. Now off to rebend and recoat the line.
Comparison of 79 line to 81 fuel line
Rear end comparison
New flare end installed
Rear end comparison
It will be painful :)
This was not a fun or satisfying job - it sucks. But many have done it ,including myself about a month ago. Worked on it for 2 days - order some of the tools suggested and eventually got it [with an extreme amount of force]. Still like to smack me some German Ape - the radiator connections were not much better - uggg. Good Luck my friend -
So for the sake of those who find this thread in the future, the fittings are available but not easy to find. I received this in the mail today. Company is called FED Hill and they specialize in lines and fittings. They also have the proper 10mm line. Note that they list the fitting as 16mm but it is actually 17mm and an exact match.
