928 Forum 1978-1995
Sponsored by: 928 Specialists
Air Conditioning Help Needed - No Power At Pressure Switch
Old 06-29-2016, 10:48 PM
996Fever
996Fever's Avatar
Default Air Conditioning Help Needed - No Power At Pressure Switch
Hi. I need some help troubleshooting my AC. 1986.5 928S Automatic. The other day my AC compressor clutch stopped engaging. My neighbor is an AC, but unfortunately not a 928 guy.
I have power at the fuse in position 8 and a good fuse. The AC button on the controller lights up when pushed with the fuse inserted, so I know power is making it that far.
I have no power at either pin on the pressure switch on the side of the dryer. I tested the pressure switch, and it is in the closed position as it should be. If I run power from the Jump port on the fender to either pin, the clutch kicks in and the AC is ice cold.
Also, it has a full charge. Once we figured out how to jumper it, he drew it down to a vacuum, and then we added a full 37 ounce R12 charge by weight just to make sure it had a 100% fill. So it's not a freon issue.
I just do not know the proper order to trouble shoot it or where to look. Any help is greatly appreciated.
Randy
1986.5 928s Automatic
2001 911 996 Cabriolet
Old 06-29-2016, 10:54 PM
SeanR
SeanR's Avatar
Check to see if you have power at the freeze switch. If not then chances are your HVAC control units internal relay has failed.
Old 06-29-2016, 10:56 PM
SwedeInSiam
SwedeInSiam's Avatar
Sounds like a freeze switch problem or most likely the relay inside the AC headunit.
https://rennlist.com/forums/928/6788...re-w-pics.html
Old 06-29-2016, 11:00 PM
996Fever
996Fever's Avatar
Thank you for your input. How hard is it to get at the freeze switch? Is that the one in the dash with the small vent thingy? And, if so, can you just pull it out of the dash to test/bypass it, or do I have to go at it some other way?
Thanks again
Randy
Old 06-29-2016, 11:04 PM
SwedeInSiam
The freeze switch is under the cover behind the air filter. See post #1 in the link I posted
Old 06-29-2016, 11:11 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,072 Likes on 1,183 Posts
I have a feeling this is in my future with the 87 and I already have a relay (or 3) in the parts bin.
Side note.....is there an "easy" way to pressurize the A/C systems to check for leaks but also test the pressure switches? I know the typical method is to evacuate the system and see if it holds a vacuum, I always found this odd. The system needs to hold pressure not vacuum to function properly and I've seen more than one A/C system hold a perfect vacuum only to leak out all the freon once added. It seams like a better test would be using a compressor and regulator, bring the system up to the maximum intended pressure and check for leaks.
Old 06-29-2016, 11:30 PM
996Fever
996Fever's Avatar
Wow. Thank you Anders. That write up from Dwayne is spot on. I love a tutorial with lots of pics. I'm going to test the freeze switch tomorrow. Sad part is we 1/2 way pulled off that plastic sheet cover over it, before giving up because it was hard to pull out and we assumed it only had wiper linkage behind it. I'll be in there tomorrow! I'm 56 and I've had multiple Porsche's, but even my 930 didn't mean as much to me as this 928. The Shark has always been the best car ever to me, and the one I have now is very special.
Thank you all
Randy
Old 06-29-2016, 11:34 PM
996Fever
996Fever's Avatar
Thanks again Anders. Wow, my 928 looks almost like the one in your avatar right down to the rims.
Thank you again
Old 06-29-2016, 11:38 PM
hacker-pschorr
What kind of tires are those? Interesting tread pattern.
Old 06-29-2016, 11:44 PM
996Fever
996Fever's Avatar
They were some funky all season tires the 86 year old original owner Lawyer I bought it from put on it just in case the world would come to an end during winter and it would need to be driven. I replaced those 4 days after getting it (notice in the pic it still had it's temp plates on). He took awesome care of it and provided me with a 6 inch thick pile of maintenance receipts. Everything works perfect on the car with the exception of the cruise control only working when it feels like it. Interior is like new with not even a bit of dash pull by the vents. Even the tire compressor, bulb kit, and everything was there.
Old 06-29-2016, 11:53 PM
SwedeInSiam
Nice, which blue is your car. Looks a bit lighter than mine.
If you need to change the relay in the headunit and you can't find a relay to fit as in Dwayne's thread the you can do as I did. I just took the original relay out and soldered in wires to come out of the headunit and connected them to a normal Bosch relay. That will last forever.
Old 06-29-2016, 11:54 PM
hacker-pschorr
Makes sense, my first thought was snow tires except on chrome rims would be rather odd.
Carry on...I have a weird interest in tire tread design and wish I could get a "new" set of 80's vintage Goodyear Gatorbacks
Old 06-30-2016, 12:14 AM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Originally Posted by Hacker-Pschorr
I...
The system needs to be absolutely dry, so the easy answer is to use some dry nitrogen. Not the stuff you get at the tire store unless you start out with an evacuated (vacuum...) air tank, and their nitrogen has a dew point of -50ºF or so. The safest way to get the right nitrogen is to buy a small cylinder of it from a welding supply store, along with a regulator and some fittings that will let you connect to your gauge set and the car.
If you --really-- want to find --all-- the leaks, grab a cylinder of helium at the party supply store, and rent a helium gas detector to sniff the system. Helium atoms are, um, pretty small, and helium is rare enough in the atmosphere that a sniffer will find traces of it. When chasing down leaks in low-pressure systems, helium is the weapon of choice. We pull a vacuum on the system, set up the helium sniffer in the exhaust of the vacuum pump, then go fog all the connections and other possible leak spots with helium until the detector screams. If you can make your AC system helium-tight, you'll hove no trouble keeping the relatively-massive R12 molecules trapped inside.
Go with the nitrogen.
Old 06-30-2016, 12:21 AM
hacker-pschorr
Nitrogen sounds like a good plan.
I suppose propane and a lighter wouldn't be the best idea?
Old 06-30-2016, 12:28 AM
996Fever
996Fever's Avatar
Hi again. Mine is a 999 "paint to sample" color. He had it painted by Porsche to match an old 911 he had. It is in amazing condition for 30 years old and has larger than normal metal flake. It looks awesome, and reminds me of the color of my 69 Mustang Mach 1 I had 40 years ago.
Quick Reply: Air Conditioning Help Needed - No Power At Pressure Switch
