A few loose connections / plugs
Hi guys,
being a fairly new 928 owner, I have to take everything apart, and from what I read, once you start, it'll never end.
While taking apart my 928, I have discovered 2 loose connections under the drivers seat, and 1 loose connection under the passenger seat.
Could someone tell me what they are for?
I tried following the line, but they disappear under the carpet.
These are under the drivers seat. The first picture seems to be the same connection/plug as under the passenger seat. Perhaps seatbelt sensor?
Lastly there is also a loose connection under the center console, although I'm not sure whether it's actually supposed to be plugged into something, or it's simply there to connect the 2 incoming cables.
Thanks!
Thanks!
1980.
Seatbelt warning light doesn't work, so I figured that would be it, but what would the second picture plug be for then?
And I don't think the last picture is for the power antenna, that one is attached to another bundle that is purely radio related. (I checked it already)
Were heated seats only for the drivers seat, or should I look for another connection under the passenger seat as well?
And as long as we're on topic, where should I plug the seatbelt plugs in? I haven't really seen a plug to stick them into anywhere.
Thanks for the replies so far.
