Looking for short shift kit
I had the 928MS kit before switching to my 6-speed Z06 trans and liked it quite a bit. I also had their Precision Rear Shifter Coupling & their Precision Shifter Ball Cup. The 3 of those things combined made for very precise shifting with good action. I've sold the SSK but still have the Coupling & Ball Cup for sale in my 928 parts ad ($175 for the pair). Here are pics, a link to the ad, and links to the parts on the 928MS site. Let me know if you're interested.
928MS Site
http://www.928motorsports.com/parts/...r_coupling.php
http://www.928motorsports.com/parts/shifterballcup.php
Rennlist Ad
https://rennlist.com/forums/928-foru...model-too.html
928MS Site
Rennlist Ad
[QUOTE=Petza914;13256643]I had the 928MS kit before switching to my 6-speed Z06 trans and liked it quite a bit. I also had their Precision Rear Shifter Coupling & their Precision Shifter Ball Cup. The 3 of those things combined made for very precise shifting with good action. I've sold the SSK but still have the Coupling & Ball Cup for sale in my 928 parts ad ($175 for the pair). Here are pics, a link to the ad, and links to the parts on the 928MS site. Let me know if you're interested.
/QUOTE]
Do you think replacing those 2 parts, without a SSK, would tighten up the slop in my shifter?
/QUOTE]
Search around. You can make a shorter shifter to your liking with a hacksaw. The "short shifters" sold commercially have the pivot points moved apart in addition to being shorter. It's more "precise" but also more touchy. The "Broom handle" that they did stock is too long and looks silly, frankly.
Tightening up the linkages is another issue. When you've got the handle out it'd be a good time to replace the nylon bushes. Looseness is usually at the front cup or rear coupler.
Shifter link: https://rennlist.com/forums/928-foru...r-get-one.html
Check out the links on the website to see what Carl says about those parts. There are also some DIYs in the forum on how to go about installing them with some tricks.
My Son just did this change out with the 928MS front and rear linkages as pictured above. The front ball cup wasn't too bad when he took it off but the rear linkage was like a wet noodle. Those rear bushing were completely shot.
Now the slop is just plain gone.
And agree whole heartily that changing out the front assembly is a total PITA! Definitely a right of passage to owning a 928.
I have the perfex mfg. ssk on both of my 928s. Quite happy with them, but if you got slop, you will probably need to replace the front ball cup, and rear bushings....the lizard kit will eliminate the front ball cup, and is a very wise choice. Roger at 928s r us sells lizards, I believe.
