928 Forum 1978-1995
Sponsored by: 928 Specialists
Is the 928 100% a Porsche design?
Old 05-04-2016, 02:54 AM
  #61
DoubleNutz
USMarine
DoubleNutz's Avatar
Cool
Originally Posted by Hacker-Pschorr
On that note....with regards to GM being first on stuff. The Pontiac Tempest had a trans-axle before the 928 did.
Yes, it was known as the "rope drive."
Old 05-04-2016, 03:21 AM
  #62
DoubleNutz
USMarine
DoubleNutz's Avatar
Originally Posted by docmirror
I'm still trying to figure out what "yute's" are...
Old 05-04-2016, 11:16 AM
  #63
Vilhuer
Vilhuer's Avatar
Reason why alusil worked better in Porsche engines than on Vega motor was casting process. Problem in Vega was that when block was cast two materials would not stay uniformly mixed until casting solidified. This lead to uneven casting where silicone wasn't present in needed quntity on some spots. Result was same as what happens when overbored 928 cylinder walls aren't properly done.
Famous Cosworth DFV 3L F1 V8 engine had solved this problem already years before Vega problems by turning casting upside down during its cool down period. This made sure material distribution was uniform in areas where it mattered. Porsche or more likely actually Mahle solved same problem by controling how casting cooled down. Same process has been used in many other engines. More info about the process is available for example in this document.
https://trid.trb.org/view.aspx?id=197260
http://papers.sae.org/830003/
http://www.w124performance.com/docs/...nditioning.pdf
Old 05-04-2016, 11:17 AM
  #64
DKWalser
DKWalser's Avatar
"Utes" are members of an American Indian tribe (or students at the University of Utah). I never understood why the judge couldn't understand what was being said.
Old 05-04-2016, 11:31 AM
  #65
dr bob
Chronic Tool Dropper
dr bob's Avatar
The Bosch CIS injection used on the early cars has traceable history to the Kugelfisher (sp?) mechanical injection found in some 1960's M-B cars, among others. Bosch bought the company and rights, refining it into the CIS system we all know and love.
Remember also that Porsche was contracting assembly services to M-B for some of their performance models. They had hands-on (literally) access to the developments at M-B. I can speculate that the decision to build the 928 was influenced by the number of premium-priced S500 they assembled for Mercedes.
Last but not least, engineers and even more so designers/drafters are a shifting labor pool. As Tony Lapine and his group came over from GM in Europe, I'm sure that group also included folks who had penned designs for other companies including M-B. Safe to say I think that the styling and a lot of the execution was revolutionary, a massive amount was/is evolutionary. Consider that engineering is a science of avoiding making the same mistakes again. The design and engineering target that is the 928 undoubtedly started with a list of requirements, and also a list of things that were to be avoided.
Old 05-04-2016, 12:37 PM
  #66
GT6ixer
GT6ixer's Avatar
Originally Posted by Jherriott
But I think we have gone WAY beyond splitting hairs on the OPs original question. I think he was *generally* asking if Porsche had a blank sheet of in-house paper as far as body design, and engine design. I think yes.
This is true. I realize that there are lots of parts on every car that are off the shelf items or Mil-Spec or non-OEM (like electrical connectors, etc) and numerous other small bits.
The core of my question really was, and is, are there any parts on the 928 that were designed by another auto manufacture and either used as is or modified for use in the 928? So for example, parts designed and built by Bosch don't count because Bosch doesn't build cars. So far the only part identified that meets this criteria is the automatic transmission, which has its roots in a MB design and was not a 100% clean sheet design by the big brains at Porsche.
I find this thread completely fascinating. Not only about all the details, but I am blown away by the depth of knowledge that you guys have.
Old 05-04-2016, 01:18 PM
  #67
docmirror
Shameful Thread Killer
docmirror's Avatar
If Bosch doesn't count, does Porsche count? Plenty of small parts from the 911 bin found their way into various areas of the 928. That was back on page 1-ish. If by page 5 we haven't beat this to death, one could say that the 'clean-sheet' became stained along the way with some small leftovers from the 911. But - only a complete **** retentive would make note of it.
Wait - whut? gggrrrrrrrrr.
Old 05-04-2016, 01:19 PM
  #68
James Bailey
James Bailey's Avatar
Interesting read is the Porsche type 542 , the FIRST 4 door Porsche , First with a water cooled V-6 yes V -6 at 120 degrees no less ! , quite a history .....it was nearly "clean sheet" too !
Old 05-04-2016, 01:24 PM
  #69
docmirror
docmirror's Avatar
On another couple of notes while I'm in the mood, the follow-on from BMW which was a similar design process was the BMW 850. Although not as divorced from the prev line as the 928 was, going in a complete different direction with engine/trans layout, and switching from air to water cooling, the 850 project spent a shilt-load of money on design and development. It was one of BMWs greatest financial flops on record.
The 928 was as different from prev cars from Porsche as it could possibly be. Which is what engenders the 'clean-sheet' kind of statements. Compared to today's badge engineered crapola from the big 3 in the US where entire platforms are shared across lines it was definitely and departure of certain magnitude.
Old 05-04-2016, 04:44 PM
  #70
DoubleNutz
USMarine
DoubleNutz's Avatar
Cool
Yep,,, that was a "unique and original" Porsche engineering process
Old 05-04-2016, 04:49 PM
  #71
DoubleNutz
USMarine
DoubleNutz's Avatar
Lightbulb
Last I checked Bosch is is not an automobile manufacturer... or could I be wrong in that someone is driving a Bosch out there.
Of course Porsche used some of its racing and heritage engineering from the 911 to design the 928, why wouldn't they???
Old 05-04-2016, 04:52 PM
  #72
DoubleNutz
USMarine
DoubleNutz's Avatar
LMAO
Old 05-04-2016, 05:01 PM
  #73
DoubleNutz
USMarine
DoubleNutz's Avatar
It is never been unusual for Porsche to do this, it fact, it is my understanding that Porsche has even contracted with BMW to build body parts for the 996 and had help from Toyota to design the 996 and Boxster.
Old 05-04-2016, 05:06 PM
  #74
DoubleNutz
USMarine
DoubleNutz's Avatar
Not the only first for Porsche, at least Ferry Porsche. Ferry, although not in the, Porsche Automobile Manufacturer name, is credited for creating the very first all wheel drive electric car as well as the first all-wheel, or FWD, drive cars. Auto Union, today known as Audi, also has much of is early winning racing history owed to Porsche.
The Porsche name is credited for many engineering firsts industry wide across all automobile manufacturers for something that may be built today under another manufacturer marque.
Old 05-04-2016, 05:14 PM
  #75
DoubleNutz
USMarine
DoubleNutz's Avatar
+1 and directly on point!
Quick Reply: Is the 928 100% a Porsche design?
