928s for Sale
#1531
I have my car on Craigslist if anyone knows someone looking for a really nice 1986 928, 5 speed manual with heated seats, mint interior, panamera wheels, new tires and brakes, new TB/WP service with PKT and also new diaphragms for heat/AC vents. AC works as does everything else and power sunroof too. 26K miles.
Here is link: https://cnj.craigslist.org/cto/5942051619.html
#1532
Howdy everyone!
I have been a lurker for a while but am considering jumping off the high dive into 928 ownership. Actually headed to see this car today:
https://austin.craigslist.org/cto/5949673555.html
I have read much of the good-luck-here's-what-you-need-to-know-as-a-newbie posts, so basically I know that I don't know at all what I'm getting into. Which is great, I'm ready for that.
Goal for 1st 928 is to 1) have fun, spend time driving because the car works and 2) learn about classic car ownership. I'd rather not spend all my time and money in the shop, and I'm not looking for any concourse ogling. I just want to drive a badass old sports car. Like y'all do.
So, is there anything else any of y'all can glean from this post that I should check out? And does anyone have a current reccomendation for an Austin 928 mechanic?
Thanks in advance,
John
Thanks in advance,
John
#1534
Howdy everyone!
Thanks in advance,
John
Thanks in advance,
John
Firstly you may be better served with this being a thread in its own right. ( someone may be able to get that link in the correct format, I couldn't either).
Secondly, at first glance this car will not be a "jump in and drive", it will definitely need maintenance and care, which equals time in the garage (best if it's yours) and dollars, this is largely due to its age, not only what I see in the picture.
As you have stated you have read through the NEW VISITOR sticky so almost all you are looking for when you view the car is in that thread.
TAKE A TORCH WITH YOU, check the engine bay fuel lines on the passengers side, along with power steering lines, they will most likely be original, as you know they will need to be replaced, not expensive if you do it yourself but rather fiddly...
Find out just when the TB was replaced, from the relatively average photo of the engine bay, nothing looks las though it has been recently removed apart from a shiny hose clamp on a water hose.
The hard vacuum line from the plenum is bent or broken, all this suggests to me is the PO does not really care, I am pedantic though, just my 02c on that.
The air filter is in upside down (read above), of course you won't turn it the correct way now!!!
When I took my OB for a test drive and warmed her up I noted any vibrations etc... I also parked her up, handbrake on, and selected all gears with the shifter, I then placed her in P, left her running and viewed the Automatic Transmission sight glass/reservoir to ensure the fluid was between the min/max level, just my way of ensuring the PO had kept that fluid correct.
The interior looks about right for the mileage, oh and I love that phone!!!!
I can't add a lot more John, I am a Newb myself, who spends far too much time thinking about my OB
Good Luck
Kiwi
#1535
Team Owner
John that car looks good enough to do what you think your want to do,
for how long hard to say.
What I would do first is put the check book away and go drive a few of them first.
While your doing that , you may find a better sorted out car for close to what your about to spend on this beauty.
NOTE you wont really understand this advice till you follow it, but that will be hind sight.
Good luck on any path you choose.
#1537
cl: 1989 Porsche 928 S4 - $4500 (Lawrenceville, GA)
89 S4 in GA
WP0JB0921KS860225
In dreadful shape. Has not run in years. Owner is asking $4500
Factory Specs for VIN Number WP0JB0921KS860225
1989 928 S4 U.S. 0165
Production Number Country Order Code
Number 165 out of 1190 produced for 1989 928 S4 U.S. market. US 928910
Engine Info
Engine Code Engine Size Comp Ratio HP SAE Torque: ft-lbs FI System Qtr_mile: sec 0-62mph: sec Top Speed: MPH Weight
M28.42 5.0L-32v 10.0:1 316 317 LH-Jetronic 14.5 6.3 165 3550
Transmission Info
Transmission Code Transmission Serial Number Range Final Drive Ratio Notes
A28.16 4-speed Automatic A28161K00001 to A28161K10000 2.54
Options
Option Code Description No of 1989 cars with this Option No of '80-'95 cars with this Option
M018 Sports Steering Wheel with Elevated Hub -30mm 505 4264
M139 Seat Heating System, Left Seat 1382 10854
I158 Radio, Blaupunkt Monterey (1986) or Reno SQR 46 (1987) 926 13989
M220 Locking Differential - 40% (87-89) 1927 12515
M418 Side Protection Moldings 1166 17506
M570 Air Conditioner with Improved Efficiency (Rear A/C) 1286 7191
I586 Lumbar support - Left Seat 697 5482
M650 Electrical Sliding Roof 2979 38586
I980 Seat Cover - Draped Leather (Front Seats in Supple Leather) 1180 5568
WP0JB0921KS860225
Engine Info
Transmission Info
Options
#1538
#1540
I bet there is accident history - brace is bent and left fender is not original.
#1541
Not sure this counts as a real 928...I saw the term transgender used recently around these parts...this ones in the GTA.
http://www.kijiji.ca/v-cars-trucks/oshawa-durham-region/1980-porsche-928-s-coupe-2-door-5-0-mustang-motor/1230025902?enableSearchNavigationFlag=true
Sonny
Sonny
#1542
Team Owner
some one hooked a tow rope to it and pulled the car
#1543
Looks very nice with only big negative being the dash. Parts car is the same paint and interior!
http://batonrouge.craigslist.org/cto/5952182391.html
#1544
It does appear to be a pretty decent deal though...
#1545
Very nice color...Hellblau Metallic '81 5-speed with original radio no rubbies and all leather interior
https://www.cargurus.com/Cars/invent...ting=164025086
https://newyork.craigslist.org/wch/cto/5920761532.html
