Firewall opening question
To the left of the wiring harness there is another wire loom that enters the cabin. There does no appear to be any waterproof grommet that might prevent moisture from migrating from the engine bay to the CE area.
Should I be worried that water will enter the cabin from this hole?
Is there something missing that would prevent the water for going in the cabin?
Here is a picture of the firewall holes. All three have rubber "grommets". The one furthest to the passenger side is the entry for the ABS harness and that harness has a rubber grommet on the harness itself. It does slide fairly easily along the ABS harness, so possibly it has been pushed back in on the cabin side.
Cheers!
Carl
Cheers!
Carl
From above the CE panel I can see open cell foam, but there is nothing to push it with. The foam simply deforms.
Found the rubber grommet and wrestled it into position. Thanks.
