928 Forum 1978-1995
Sponsored by: 928 Specialists
Deciphering the PET - Parenthesis
Old 04-24-2016, 10:46 PM
ltoolio
ltoolio's Avatar
Default Deciphering the PET - Parenthesis
Been meaning to ask this for a while.....
What does it mean in the PET when there is a duplicate number from the illustration, with one of the part numbers in parenthesis?
Old 04-24-2016, 11:32 PM
Wisconsin Joe
Wisconsin Joe's Avatar
PET editions usually cover multiple years. For example, the one I use covers to 83 to 86.
There are some things that changed over those years, and there are different parts in the same place.
I think that's what you are seeing.
Old 04-25-2016, 12:14 AM
Vilhuer
Vilhuer's Avatar
Part is different compared to what's in picture.
Old 04-25-2016, 11:48 AM
harveyf
harveyf's Avatar
Look out in the Model column. In most cases, the number without the () will go up to a certain model year (or engine no., etc) and then the number in () will pick up after that model year.
If you want to see a really graphic example, look at the pages for pistons and rings!
I'm also seeing letter codes under Remarks. These codes are also in (). These are explained on the last pages of the PET and are the country codes.
There's actually a ton of good info in the back of the PET, on the V pages. Also a summary of the Option Codes, right before the V pages.
Old 04-25-2016, 12:10 PM
ltoolio
ltoolio's Avatar
Thanks, guys.
I've seen the model year designation before, so I was good on that. In my case, the PET spans '78->82, so I often see -79 and 80- in the column.
In this case, the MY difference isn't called out so was/am just a bit confused and I can't see where the two hex-head bolts go. And for the record - not worried about it either.
As I opened with....just curious here.
Obviously no big deal here, as we are only talking about the dust shield for the rotors
And good tip on the end pages of the PET...never scrolled to those. Lots of good info.
Old 04-25-2016, 06:55 PM
Vilhuer
Vilhuer's Avatar
M6x15 hex heads replaces M8x20 pan heads. They go same holes but part which they thread to has to be obviously different. Picture in PET still shows M8x20 but actual part used in this case is M6x15 hex head. Thats what parenthesis means. Picture is not accurate representation of actual part. Factory didn't bother to make new picture every time something changed. They just added lines to parts list.
Quick Reply: Deciphering the PET - Parenthesis
