928 Forum 1978-1995
Sponsored by: 928 Specialists
fuel pipe/vent pipe help
Old 04-23-2016, 02:42 AM
h2pmr
h2pmr's Avatar
Default fuel pipe/vent pipe help
am doing up an 88S4 which is in need of the 2 long metal fuel pipes and the tank vent/ charcoal canister pipes.
I am in need of a picture of the 4 pipes that run along the floor that shows which pipe is fuel and which is venting.
I have fitted the 2 fuel pipes before on other S4's and know what a pain they are to fit but need the pictures as the pipes on at the moment are far from the standard routing....
cheers
Phil
Old 04-24-2016, 01:53 AM
h2pmr
h2pmr's Avatar
one of the vent pipes from the carbon canister has a join with a rubber pipe 999 181 716 50, if anybody knows if it is the far outside or a middle pipe of the 4 I think I will be able to work out the rest of the routing.
cheers
Phil
Quick Reply: fuel pipe/vent pipe help
