928 Forum 1978-1995
Sponsored by: 928 Specialists
Sill repair panels
Old 04-17-2016, 01:40 PM
C531XHO
C531XHO's Avatar
Unhappy Sill repair panels
Hi Everyone,
I have recently purchased an S2 which looks very good apart from some corrosion in the external sills (floor and inner look fine). Does anyone supply replica panels/repair sections or is the only option to make up sections. There is no way I can justify ~£1200 that Rose Passion seem to charge for panels and there don't seem to be other providers..
Dave
'85 S2 Auto
Old 04-17-2016, 09:50 PM
James Bailey
James Bailey's Avatar
Those door sills are an important part of the chassis... as a uni-body car those are the bones. They really never seem to have corrosion issues in the U S so little demand for replacements.
Old 04-17-2016, 11:15 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Door sills are listed in PET, so there's hope that a set exists in someone's inventory. Worth a look. Mark may have good used ones. Or will section a shell before it goes to the grinders.
Old 03-14-2017, 04:33 AM
C531XHO
C531XHO's Avatar
So latest is I cut out the rot and discussed with my local classic car shop. The panels are pretty simple so we can fabricate from flat sheet. Only real profile is roll and flange for the sill section. Have done this in the past but without a proper workshop/bench vice and ideally access to cropping/folding/rolling equipment it will be too difficult so it going away for them to work their magic. Will post AFTER pictures..
Old 03-15-2017, 02:24 PM
davek9
davek9's Avatar
I'd suggest finding a wreak and cutting off what you need (cut it bigger), then weld it back in place of the rotted section.
Dave K
Old 03-17-2017, 11:52 AM
RennPartsDirect
Former Vendor
RennPartsDirect's Avatar
If you can't find what you need I will have two different sets of sills to pick from to cut out for you...
Old 03-17-2017, 11:56 AM
C531XHO
C531XHO's Avatar
Thanks UNEEKONE, that's a kind offer. Will keep it in mind once I have spoken to the welder
Quick Reply: Sill repair panels
