928 Forum 1978-1995
Sponsored by: 928 Specialists
Cracked Maunal Transmission Case - Need solutions
Old 03-28-2016, 02:34 PM
Michael Benno
Michael Benno's Avatar
Default Cracked Maunal Transmission Case - Need solutions
Hey folks
I found the source of my leak I posted a few weeks ago: https://rennlist.com/forums/928-foru...l#post13110073.
I have a crack in my 1988 S4 5spd transmission case. Apparently the crack was patched using a compound like JB Weld or something, and the leak has re-emereded. Unfortunately this was not identified by the two PPI's I had done.
So now I am trying to figure out what to do. I understand my options would be:
1. Re-patch: drain, clean oil out, and re-patch.
2. Weld case and rebuild transmission.
3. Replace transmission with unit a rebuilt unit
4. Replace case and rebuild transmission - which MY cases are compatible?
I sure would appreciate your input on what to do, if anyone has some vendors or spares that could be used would be greatly appreciated.
Old 03-28-2016, 02:38 PM
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
I would think it could be welded but that will probably require complete disassembly. I may have a case if you end up needing one
Chris Lockhart
Chris Lockhart's Avatar
Have you contacted 928 Intl yet, to see if they have either a trans or case that would work?
Edit: Mark beat me to it. LOL.
Old 03-28-2016, 02:45 PM
davek9
davek9's Avatar
Thinking it depends on what's under that glob (patch), is it a hole or a crack?
Old 03-28-2016, 03:15 PM
Michael Benno
How would this impact the repair? Is one more difficult to weld? I would think either would require a bead of weld. If a crack I suppose there is a need to terminate the crack with drilling a small hole.
Old 03-28-2016, 04:43 PM
davek9
davek9's Avatar
Right, just saying if it's cracked then weld up the crack and grind it down, verses making up a patch to fill in a hole and welding all that.
Not that it can't be done, just more time and effort and depending on the hole how will it look.
If it was mine, I'd drain it let it sit, see what you have to work with, take some pic's of the damage, clean it up w/ brake cleaner, mix up some JB Weld and reseal it.
Start pricing your options, including swapping the case w/ used one from 928 International.
Old 03-28-2016, 05:52 PM
James Bailey
James Bailey's Avatar
The metal gas tank epoxy repair kits sold at auto parts stores might work , special resins to be gasoline proof.....just seems a shame to pull the trans/rebuild for a small leak.
Old 03-28-2016, 06:10 PM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,451 Likes on 1,459 Posts
Transmission cases are made from a high grade of aluminum. Pretty simple to weld, however all of the gearoil must be removed....even the stuff in the crack to weld.
Talk to whoever is going to weld it. They may want it apart to clean the crack out, or they may think that removing, draining, flipping it over, and cleaning the crack is enough.
I don't think I'd trust anyone that thinks they can weld it, in place, with gear oil runnimg out the crack. If that was my only option....use some epoxy.
Old 03-28-2016, 10:28 PM
Michael Benno
Thanks for all the super useful information everyone. I spoke with Mark Anderson of 928 International and he gave me some good advice. Any repairs I can do with the transmission in the car is going to be the most practical, he suggested welding or re-patching.
So that is were I am going to focus my attentions. Welding seems like the most permanent repair if I can find a place to do it. I called a radiator repair place and a transmission repair place and both would not do the repair 'in car' they sited concerns about oil contaminant or difficulty connecting electrodes for TIG. Should I be looking for a automotive specialty welder?
With regards to rematching, I have been researching patch products and came across this Hi-Temp aluminum patch from Permatex. Thoughts or opinions of patch products are appreciated. http://www.permatex.com/documents/TD...tive/31372.pdf
Edit, this product looks promising as it can be thinned and brushed into the crack and applied many layers. http://www.alvinproducts.com/Product...Lab-metal.aspx
Beyond that, I would be looking at removing the transmission, and the case so it can be welded on a bench. I am going to assume the is the most economical option since cases are about $1800, and a rebuild would also be about that price. Potentially I could ship the unit of for both at the same time.
Old 03-29-2016, 12:01 AM
dr bob
Chronic Tool Dropper
dr bob's Avatar
A crack that's weeping oil will continue to weep oil so long as the gearbox is upright and there's oil in it. So start by getting the oil out, and clear the area above the crack of oil if you aren't going to take the gearbox out. Then flush the oil that's in the crack out, using solvents and ultimately some brake cleaner. Until you are willing to put your sandwich in there. You'll do the same prep for a good epoxy repair as you would for a weld repair, making a small groove that you can fill with epoxy. Clean it again thoroughly before you epoxy.
The "patch" that's visible now looks like someone just smeared some epoxy over the crack rather than trying to repair it. There are some epoxy products that might be OK for that, but they are different from what you'd use for a repair. A surface band-aid patch needs to remain flexible, or it's just a matter of time before it weakens and leaks again. A good bond needs the surface roughened, and must be surgically clean.
I've seen some real artisan work done on aluminum cases both with epoxy and with the TIG torch. The welded solution is generally more secure if done correctly.
Old 03-29-2016, 12:24 AM
GUMBALL
GUMBALL's Avatar
I have had trans cases and engine oil pans welded in place on the car. Porsche trans cases are made with good aluminum, very easy to weld.
You need to find a very good TIG welder. Drain all the oil, get a couple of cans of GOOD brake cleaner and flush the oil out of the crack. Use compressed air to blow the crack clean. Repeat - spray break clean, blast with air . . repeat as often as necessary until clean.
Blow dry, and blow air into the trans case to flush out all brake cleaner fumes. Then it should be weldable. Start at the ends of the crack and weld towards the center. Don't be afraid to lay a heavy bead. If necessary to make a second pass, let the case cool for a while first.
Old 03-29-2016, 12:26 AM
Michael Benno
Great info, can you recommend some good patching products that you have used or seen used?
Old 03-29-2016, 12:41 AM
Michael Benno
Thanks for the tips, I'll keep searching!
Old 03-29-2016, 12:42 AM
Ducman82
Ducman82's Avatar
interesting where it cracked. id like to see under it. if the trans is drained, and the crack is SUPER cleaned, id use high powered blasts of brake clean and allowed to dry, i could TIG it in place... but again.. SUPER clean. as Greg said, the case metal is a nice high quality metal, melts like butter with plasma.....
Old 03-29-2016, 01:01 AM
Lizard928
Lizard928's Avatar
I would remove from car, drain, turn upside down, clean with NON CHLORINATED brake clean, heat it with a torch, clean again, then weld with TIG.
Quick Reply: Cracked Maunal Transmission Case - Need solutions
