928 Forum 1978-1995
Sponsored by: 928 Specialists
1987 intake refresh. What is this part?
Old 03-01-2016, 05:42 PM
johnu
johnu's Avatar
Default 1987 intake refresh. What is this part?
Can someone tell me what this capped off metal tube is for and where it leads?
John
Old 03-01-2016, 06:08 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,251 Likes on 1,245 Posts
this is an air sample tube there should be one in either side of the exhaust manifolds,
this port samples the air before it reaches the cats
Old 03-01-2016, 06:40 PM
johnu
johnu's Avatar
Is that for emissions testing or something?
Old 03-01-2016, 06:55 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
its for when they are setting engine up at the factory
Old 03-01-2016, 07:52 PM
johnu
johnu's Avatar
John
Old 03-01-2016, 08:57 PM
Adk46
Adk46's Avatar
I'm going to remove mine in the next few days; they get in the way a bit when dealing with the valve covers. I'm also going to remove the air pump tubes. I don't need any added difficulty.
I've read the tip that the sampling tubes, at least, can be plugged by inserting a ball bearing in the flare and screwing on the nut. I have a few sizes ready to try. Not sure about the air pump tubes - they're bigger I think.
Old 03-01-2016, 10:22 PM
johnu
johnu's Avatar
I had to move mine out of the way to get to one of the bolts. Didn't want to break something potentially important!
Old 03-02-2016, 09:26 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
the best fix is to spray the B nut with PB bl;aster a few times,
then remove it and wiggle the hose from the fitting,
then install a ball and the B nut that you have freed from the hose.
Old 03-02-2016, 04:28 PM
johnu
johnu's Avatar
ok, so now that engine lift bracket is preventing me from removing the driver side cam cover. Do I need to remove the bracket or is there another way?
Old 03-02-2016, 04:43 PM
johnu
johnu's Avatar
Loosened the single bolt on the bracket enough to slightly move it out of the way. No problem after that
Old 03-02-2016, 04:49 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Up here in the rust belt, most of those tubes rott away by the time the car is 15 years old.
Old 03-02-2016, 05:05 PM
Lizard928
Lizard928's Avatar
And here is what we expect it to look like when you're done. Hahaha
Old 03-02-2016, 09:31 PM
johnu
johnu's Avatar
Hardly!
Very nice!
Not sure if I will powder coat. My original coating is about 95% complete. Might just paint it
Old 03-02-2016, 10:03 PM
MFranke
MFranke's Avatar
An old lug nut also works to cap the port at the exhaust.
Quick Reply: 1987 intake refresh. What is this part?
