Which 18" Panamera Rims?
I have a White 1988 S4 and was looking for a set of 18" Panamera rims when I came across a deal too good to pass up. The rims I ordered are the 5 spoke Panamera rims even though I was looking for the 10 spoke ones. Here is a pic of a 928 on 5 spoke rims:
https://rennlist.com/forums/attachme...-pict0014c.jpg
I also found a few pics of a white 928 S4 on the 18" 10 spoke Panamera rims
https://i.ytimg.com/vi/mDO6f7rbOFk/maxresdefault.jpg
I can get a set of the 10 spoke wheels, but am not sure I should. I like both, but I believe the 10 spoke ones look more modern. What do you guys think? 5 spoke or 10 spoke look better on a white S4?
I have the 10 spoke and agree. I've never looked, but there's probably a brush made for them--something for the brake dust behind the spokes. For the OP, check out this thread: https://rennlist.com/forums/928-foru...set-owner.html
Dunno if this problem is typical of other wheels or not but be aware that the when fitting the 10 spokes you will likely need to pull off the front bearing grease caps and cut about 1/4" off the lips or else the wheel center caps won't clear. Took no more than 10 minutes and 3-4 dremel cut off wheels each.
https://rennlist.com/forums/928-foru...gimme-pix.html
