928 Forum 1978-1995
Sponsored by: 928 Specialists
Dash pod upgrade
Old 01-28-2016, 07:15 AM
howdog928
howdog928's Avatar
Default Dash pod upgrade
In too deep now, lol. I have finally embarked on a much needed upgrade to my instrument cluster/pod area of the '88 S4. For a few years now I have been running with an inop odometer (despite it being 'fixed' before) and no pod lights. My alternative, shamed to say, has been a cap light from Walmart velcro'd to the pod in front of the gauges!!
Time for an upgrade!
My plan is to a) Get the odometer fully fixed
b) change out all pod lights for LED.
I have been in touch with Ed Scherer on the LED dimmer and his thread plus a few others to see what LED upgrades they did. As yet I don't see a definitive list for all the LEDs in the pod for an '88. Ed's was on a later model. So I will provide that list as things progress. I count 3 larger bulbs and 20 smaller ones. I'll have to figure out what colors all the smaller ones need to be.
Pics of what was and progress on pulling the pod so far. On first look, the odometer cog seems to be in one piece so not sure what the problem is in there. The black surround inside the pod is really badly dirty/oxidized and will need a damn good clean and I'm hoping to prize off the 'glass' front if I can without breaking it to make that easier.
To be continued...
Old 01-28-2016, 10:46 AM
Ed Scherer
Ed Scherer's Avatar
Thumbs up
I'll be watching this thread with great interest.
And I'll be happy to update Converting Porsche 928 Interior Lighting to LEDs based on your findings. The absence of good information on the pre-'89 cars has been a major deficiency in that guide for a number of years.
Good luck on your project.
Old 01-28-2016, 11:14 AM
bureau13
bureau13's Avatar
At some point I'm going to need to do this on an '86.5. Yours is pre-digital dash, right? I wonder how different it is from mine?
Old 01-28-2016, 12:55 PM
buccicone
buccicone's Avatar
Howard, Jake posted yesterday similar odo problem.
https://rennlist.com/forums/928-foru...-question.html
I have the Jager LED kit to install in '86.5 "Blackie"
If you give up on the speedometer, I have an extra I can sell that was professionally repaired. I believe it had the drive motor repaired/replaced.
Old 01-28-2016, 01:03 PM
Kevin in Atlanta
Kevin in Atlanta's Avatar
Replacing the dash bulbs is a nice upgrade. But, the one lighting upgrade that has gone unanswered for us poorly illuminated pre 89 owners is better lighting so you can see the instrument panel during the day. I have been toying with DRLs for instrument panel illumination for a while. I think the lights are turned on with a switched ground.
Old 01-28-2016, 01:12 PM
buccicone
buccicone's Avatar
Howard, 2016 calendars are in for the club. pass the word.
Old 01-29-2016, 07:05 AM
howdog928
howdog928's Avatar
Thanks Ed, you've been a big help so far. Here is the pic of one of the 20 bulbs I mentioned in the pm.
Old 01-29-2016, 07:06 AM
howdog928
howdog928's Avatar
Jeff, yes, it's pre-digital dash, probably very similar if not the same as your.
Old 01-29-2016, 07:12 AM
howdog928
howdog928's Avatar
Hi Mike,
I have the Jager kit on it's way too, but wanted to change all the warning lights to LED too.
I took a look at Jake's thread & Dwayne's odo repair and while looking at mine and checking the play I found one of the small cogs had no play. Applied a bit more pressure and it 'popped' back into place! Good news, but now I'm wondering why it got out of place originally so may need to do the washer in there to prevent it happening again. PO had it fixed for me when I bought her, but only lasted a couple of weeks.
I'll ask Joel if he can hold a calendar for me
Old 01-29-2016, 10:37 AM
buccicone
buccicone's Avatar
Joel & I will have calendars with us during the season at any shows.
Old 01-29-2016, 12:30 PM
Ed Scherer
Ed Scherer's Avatar
I think that is a B8.3D bulb. See Super Bright LED's page B8 LED Bulb - SMD Instrument Panel LED and check the dimensions of the base part of the bulb to make sure.
As to the main three bulbs for the main cluster illumination, I believe that has been covered in some other threads; see if a search can turn up anything.
Old 01-29-2016, 06:01 PM
Wisconsin Joe
Wisconsin Joe's Avatar
...I took a look at Jake's thread & Dwayne's odo repair and while looking at mine and checking the play I found one of the small cogs had no play. Applied a bit more pressure and it 'popped' back into place! Good news, but now I'm wondering why it got out of place originally so may need to do the washer in there to prevent it happening again. PO had it fixed for me when I bought her, but only lasted a couple of weeks.
If it locked up once, it will do it again. As I noted in Jake's thread, it takes a surprisingly small amount of play for it to be able to lock up.
Old 01-29-2016, 06:54 PM
howdog928
howdog928's Avatar
Point taken, I'll get it fixed while it's out of the car!
Old 01-30-2016, 12:19 AM
Chuck Schreiber
Chuck Schreiber's Avatar
You'll dig the Jager upgrade, it's awesome!
On the other hand...
In my opinion, after having the led upgrade on all my gauge, pod control, ac head unit, clock, etc... The warning light led upgrade is overkill. (Std light bulbs are ok here as they are NEVER ON.. Or at least you don't WANT them to be)
My take on having the idiot lights converted to LED's is that I don't want them "shouting" At me any more than the other std bulbs would.
The biggest difference you'll get is the "billboard" illumination on the gauges, the pod control bulbs (#74) and the center console illumination.
Polish the clear Lense over the gauges
Spray the gauge surround w FLAT BLACK
replace odo gear
Replace warning light bulbs w std bulbs
Column bushing and bearing
Clean connectors on circuit board and replace circuit board if you can find one
Recover pod w vinyl or leather
Replace ignition switch
Good to go!
Old 01-30-2016, 08:28 AM
howdog928
howdog928's Avatar
replace odo gear
Good to go!
Nice list chuck, especially like the input on cleaning the lens and spraying the gauge surround - def needs it. And the pod does need recovering along with the dash, but that may be an adventure for another time.
Cheers mate!
Quick Reply: Dash pod upgrade
