928 Forum 1978-1995
Sponsored by: 928 Specialists
Locked key in car
Old 12-01-2015, 10:57 AM
Flint
Flint's Avatar
Default Locked key in car
In an absent-minded moment while doing some troubleshooting, I managed to lock my keys in the car. The car is off the street in a secure area, and I don't need it to drive, so I can afford to take my time with the least "invasive" method of basically breaking in.
I've read about basically yanking on the hatch until the receiver breaks, or taking out one of the curved hatch side windows, but if I can be even less damaging than that, even better. My door locks are already shot (I had to open the hatch and reach in to lock/unlock the car with the internal ****, hence part of why I didn't realize I left the keys in), so if there's a way through there, I'm especially interested since I'm going to have to re-key eventually anyway.
Thanks.
Flint, '84 Euro-S A/T
Old 12-01-2015, 11:15 AM
davek9
davek9's Avatar
Try this...
Old 12-01-2015, 11:44 AM
notaguru
notaguru's Avatar
So make that gadget, and keep it in the car for next time.
Old 12-01-2015, 11:52 AM
davek9
davek9's Avatar
and ... the next time your fishing in a great place, put an X on the bottom of the boat to mark the spot
Old 12-01-2015, 12:07 PM
jetson8859
jetson8859's Avatar
Did this the first couple weeks I owned mine as the doors wouldn't stay open and I had taken the door panel off to fix a bad window motor and inadvertently put the lock down.
I tried the above with the tool with no luck as the protection plates were still over locks and the insertion of that tool has to be very precise.
Had a locksmith try for over two hours and he said that the 928 was a virtual armored car when it comes to breaking into them. The two that he had dealt with in the past both had their locks slide hammered out when stolen.
Ended up just breaking the passenger side quarter panel glass, they are cheap and I sourced one locally before breaking the glass. It takes longer to vacuum up and remove the broken glass then it does to install a new one.
Good luck and I hope you are successful!!
Old 12-01-2015, 12:10 PM
James Bailey
James Bailey's Avatar
If you can bend it to make it....it will simply bend as you try to use it....
sometimes you can unscrew the bolts which hold the upper hatch post in place getting each just a little at a time. cut down an allen key so it fits
quickest is to break the rear 1/4 glass since the seal costs more than the glass !
there is also a hole in the floor in front of the rear seat which is covered by a metal plate held in ONLY by undercoating and putty. You push it up into the car with a floor jack that lets you get your arm in the car but you need a pair of long pliers to reach the **** on the door not easy but has been done...
Old 12-01-2015, 12:30 PM
Keith Coe
Keith Coe's Avatar
I'm always fanatical about having two keys for every vehicle. If you know the key code, Keys4Classics.com can have you a new one in a week.
Old 12-01-2015, 12:31 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,555 Likes on 1,235 Posts
Old 12-01-2015, 12:37 PM
RennPartsDirect
Former Vendor
RennPartsDirect's Avatar
Why not call a licensed and insured locksmith?
Old 12-01-2015, 12:39 PM
RennPartsDirect
Former Vendor
Please ignore my previous post. Missed this bit of info the first time through the thread...
Old 12-01-2015, 12:43 PM
James Bailey
Good photos Rob...shows the hole in the floor quite well.
Old 12-01-2015, 12:44 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Grab the bottom lip of the hatch with your finger tips (right under the lock) and pull on it really hard. There is a good chance the hatch will pop open, it does on many 928s that have a slightly worn hatch lock mechanism.
Old 12-01-2015, 01:22 PM
jetson8859
jetson8859's Avatar
Wish I had known about Rennlist when I locked my keys in car! As I said it was the first two weeks Great pics, Thanks Rob!
Old 12-01-2015, 01:33 PM
PHIL928
PHIL928's Avatar
When I locked my keys in the car I used the method illustrated by Rob successfully.
docmirror
Shameful Thread Killer
docmirror's Avatar
You already bolded the part I was going to bold.
Soooooooo. How is that going to help him?
Quick Reply: Locked key in car
