Head stud
Head stud
Ok so i f-cked up a stud on the head of my 86.5 who knows where i can get the right size drill and tap to put a sert in it and move along. I do not want to think about it to much yaknow? thanks for ANY help,Ray
the stud is toast or the hole? if its the stud, cant you just pull it out by forceably unscrewing??
if you have to drill and tap... sounds like a timecert? interested to hear how you can fix the block
Basic Site Sponsor
Basic Site Sponsor
If you are asking about repairing the threads way down inside the deep hole where the head studs go, that's a tricky repair.....even with the proper tooling.
Timesert makes a Cylinder Head Bolt Universal Repair Kit (part #4800.)
This will get you to correct length tools to drill, tap, and install a Timesert into the bottom of that head stud hole. To utilize the entire kit (to center the tooling, which is very important), you will need to "create" a couple of special tools and get some different length bolts to go along with that tool.
Worth noting, Alusil is very abrasive and very hard on drills and taps. The drills and taps in that kit, although very high quality, will be trash in a very short time.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
I put to much torque on the not and it started to put the threads out. Don't ask please.Greg can you tell me where you would get that tool please? thanks,Ray
Better yet is that a 12 mm stud? And what else would i need ,I have a plate made just for doing something just like this so I am not worried about aligning it correctly. Just need sizes and its only one stud not more than that. but anything you or anyone can add would be appreciated. yea it would.
Basic Site Sponsor
Basic Site Sponsor
You can use the stuff and send it back.
You are going to play hell trying to get a stud to match the one you over tightened. The replacement studs are not the same as the ones that came in these engines, originally. (There's no chance of them taking three 90 degree turns.)
I can probably look through my "pile-o-studs" and find you one good replacement, if you need one.
How about I have Mary (office/wife) send you the stuff you need to fix it, seeing as you only need to fix one. (That kit is almost $500, as I recall.)
Basic Site Sponsor
Basic Site Sponsor
Call Mary and give her your shipping address. I'll work on some instructions that may/should help. Do you have an air compressor to blow out the hole? 1/4" die grinder ? (Depending on your block casting, you may or may not need to "clean up" the very top of the hole to get my custom locator to fit.)
Thanks for helping to keep our 928s alive!
Head Stud ... hmmmm ...
Reminds me of the time I was in the Saturday morning checkout queue at the hardware store: long leggy blonde purchases being put through by attendant. "Stud Finder ... $14.29 ..."
She felt a tap on her shoulder, and a dear little "Tweety Pie" granny asked: "Excuse me dear - do you think I could borrow that just for tonight?"
She felt a tap on her shoulder, and a dear little "Tweety Pie" granny behind her asked: "Excuse me dear - do you think I could borrow that just for tonight?"
