928 Forum 1978-1995
Sponsored by: 928 Specialists
Steering wheel locking ignition switch
Old 11-15-2015, 05:34 PM
glmoore0001
glmoore0001's Avatar
Default Steering wheel locking ignition switch
Ok, twice in the last two days, I have come out to the car, stuck the key in the switch and it would not turn.
I can move the steering wheel around and eventually get the ignition to turn, but it does not happen quickly and it has me spooked. This has never happened before, then I get it twice in two days.
There has been no work done to the car in or around the key or the pod.
Am I over reacting here, or is there a known issue here I am unaware of.
Thanks.. Gary
Old 11-15-2015, 07:04 PM
glmoore0001
Default Retry
If I pull the wheel left till it locks, to unlock, I have to pull all the way to the end of the travel till it locks while wiggling the key for it to unlock.
Is that normal? Possibly, I am overreacting here.
Old 11-15-2015, 07:46 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Do you have a keychain with other keys on the ignition key? If yes, remove them all and spray a little WD40 or something similar in there.
Old 11-16-2015, 06:54 AM
glmoore0001
Default 3 keys
Black Key, Red Key, House Key. I will try the WD though. Thanks.
Old 11-16-2015, 10:01 AM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
If the steering column locks with pressure against the system - that is, if the steering wheel isn't freely floating with no pressure in either direction - it will usually take a bit of turning of the wheel to relieve the pressure on the locking bar so that you can easily turn the key.
The above is a complex run-on sentence...
Old 11-16-2015, 11:49 AM
Jerry Feather
Jerry Feather's Avatar
Reminds me of a time a long time ago when my mother and dad got into the car with my dad in the drivers seat and when he tried to start the car his key would turn the ignition switch but nothing happened. He tried several times, and then my mother said try a different key, and she offered up hers. My dad was frustrated at that kind of "female logic," but in order to show just how stupid is was he tried it and the car started. He was beside himself.
Maybe you should try a different key?
Quick Reply: Steering wheel locking ignition switch
