9004 LED headlight bulbs
#61
"Shove a high Quality LED" with correct bulb placement in a H4 AnyDay to give the Correct Cut-Off and street legal spread of light on the road. ��
However shove a HID in a H4 or other reflector headlamp and blind everyone on the road....which is what some sellers in the USA were advocating!!!!
#62
Just to clarify the 7" H4 mentioned elsewhere in this thread should work fine with the "Shove a high quality LED" method...right? I'm confused why anyone would bother with the Jeep Nighthawk thing at something like 7x the price of the 7" H4, unless I've missed something here...
Well said!
Steve
#63
Basic Sponsor
We are well advanced in making the 8" H4 lens in the same material as we make the driving/fog light lens. You will remove the H5 lens from the light assembly and replace with an H4 lens. Then you can use the 9004 bulbs from Steve.
#65
Archive Gatekeeper
So the shape of an H5 housing's reflector is the same as the H4's reflector, and the only difference is the lens? I never dug out my spare H5's to check the Bosch P/N.
#66
Even if the reflector shape is different, the scatter pattern of the H5 lens is the real culprit I would think.
#67
Basic Sponsor
#68
Developer
http://www.928motorsports.com/parts/hellalights.php
#69
Basic Sponsor
Unfortunately the 7" Hella are just a band aid and only slightly better than the sealed beam 7" originals. I have them on some of my early cars to maintain the stock look and do not recommend them to customers unless they want to maintain the stock look.
If you really want to improve your lights the only way to go is the 8" H4. NIGHT & DAY Difference.
Once we have the H4 lens this option will be available to all with 8" H5 original lens assemblies at a reasonable price. Coupled with the new WoodyPeck bulbs 9004 you will be in light heaven 8>)
#70
Developer
BTW does anybody have a photo of the lens pattern on a garage door or anything for the GE Nighthawk idea?
I mean - several of you are sure they do not focus their beams, but I wonder if this is what you have heard, or what you KNOW?
I ask, because GE specifically claims that they are street legal, exceed all DOT requirements, and have a sharp cut-off.
From the GE product description:
http://www.gelighting.com/LightingWe...ghts/overview/
Will the lamp blind other drivers?
The GE LED headlamp has a very bright beam pattern however; the Low Beam “cutoff” is very sharp. This “cutoff” of upward light results in very little light being cast into the eyes of oncoming drivers.
- See more at: http://www.gelighting.com/LightingWe....9SBEm8HQ.dpuf
Are these LED lamps Legal?
YES. The GE LED Headlamp exceeds the DOT requirements for on road use.
#71
Developer
Still - what I do agree with, is that the absolute best looking and functioning light in a 928 is the 8" rounds. ...if you can afford them.
Given the price of the 8" round conversions ($500 EACH?), the Hella is a solid option to replace a 7" sealed beam at a much lower cost ($144 a PAIR).
#72
I've seen some reviews and comparisons of the 7" Hella with sealed-beam lights, and they did look quite a bit better to me.
Regarding the modified lens to replace H5 assemblies...that still doesn't help those of us with older cars and 7" sealed beams...does it? I'm pretty sure I still need to do something like the Hellas or go with a real (pricey) H4 upgrade.
Roger, do you know if the Hellas you tried that weren't satisfactory were perhaps the DOT-approved lights, rather than the E-code lights? Both are available, and I've read many reviews suggesting that the E-code were far superior to the others.
I disagree in part. Hella makes a great lens and reflector assembly, and the Hella H4's are a huge gain over the US-type sealed beam. Huge. Much, much better.
#73
Basic Sponsor
Actually H4 assemblies are much cheaper than $500 each.
Our price for the Porsche supplied complete H4 head light assembly including bulb is $350 each.
We also sell the 7" H4 Hella units with uprated bulbs for $115 a pair.
I can only assume you have only sold them and never driven a car actually fitted with them at night - because that statement is way OTT.
#74
Basic Sponsor
#75
Developer
Are you going to invest $700 for a pair of 8" headlights, or $115 for a pair of Hella H4's?
The Hella H4's have a place, and they are a good product. PLUS: you could easily fit them with a H4 LED bulb if you wanted to take them another step, and you'd still be under $200.
