stuck on the side of the road.
09-20-2015, 11:40 AM
So here I am stuck with a 89 GT that seems only what's to run on two cylinders. I thought it might be a limp mode...but it's only running on 2 cylinders...Any suggestions?
09-20-2015, 11:45 AM
Quote:
Originally Posted by
kmascotto
Yikes. Aside from having towed home I have no idea. LH failure maybe?
09-20-2015, 11:56 AM
Are you sure it's only two? Could be the coil on one side, or it's supply wire to the distributor.
09-20-2015, 11:57 AM
that's what I'm afraid of...since it's been running like a charm. I was running through the gears and in third, it decided to give up half dozen cylinders
09-20-2015, 11:58 AM
It will almost Idle on 2 though
09-20-2015, 12:02 PM
how do you know it is only 2 cylinders?
09-20-2015, 12:05 PM
linderpat
Exactly. How do you know? Does the 89 have the exhaust temperature sensors?
I think it's only 2 because it's running so ruff it doesn't have enough power to move itself forwards
09-20-2015, 12:14 PM
I thought about those Rod, I have the bypass on them.
09-20-2015, 12:17 PM
Hey Adam I sent you a video of the motor...can you post for me?
09-20-2015, 12:19 PM
I have new coils new wires, all grounds are done..
09-20-2015, 12:27 PM
Did you check your coil to distributor wires and the connections?
09-20-2015, 12:32 PM
Yes they are nicely seated
09-20-2015, 12:44 PM
Where is a video...I think
09-20-2015, 12:45 PM
