ac outside temp wire?
On investigating my non working horn I found this wire in the front right wing, it was just dangling and not connected to anything. My thought are its the outside temp sensor for the ac BUT I'm not sure as my UK 1980 928 dosnt have auto a/c control just manual. also isn't it on the wrong side for that?
So I opened up the other side and found this
Thoughts please gents
Looks like the temp sensor connector, but it should be under the left wing. Your whole sensor seems to be missing on the left - a short piece of metal tube with the sensor in it, and spliced into the alternator cooling hose, screwed onto the left side splash shield (very bad idea). Is there a similar lead on the left at all?
jp 83 Euro S AT 56k
jp 83 Euro S AT 56k
Chronic Tool Dropper
Alan, if you knew -anything- about the climate in GB....
Getting spoiled by the dry heat in Phoenix, where it's too darn hot for anything to actually rust?
Electron Wrangler
Alan
Yes they still salt the roads in winter
No lead on the other side at all where I would expect to find it.
I have a Manual hvac ( no automatic ac control) so didn't think I needed this outside sensor as there isn't an inside one? I'm sure someone will correct me
I'm thinking one of your horns is missing a trumpet unless the angle of the shot is hiding it.
I would say as you have a manual HVAC Head unit it not required to know what the Temp is, right?
As for the outside Temp wire, it is part of the Main under dash wire harness, so it may have been run as a "standard" job just like the fan wiring for towing or the rear Fog lights.
Yep that was my first thought but I have had the pod apart to fix the odo and know it's not from anything there and it all works
