Coke Car running lean...
#31
Thanks Ken. I'm wiped out for today. Been doing a few things on the Honey-Do list. I'll get a 87/88 FPR on order, but at least I found the culprit.
I'm surprised I didn't notice the TPS was disconnected previously. It's connected now. Thanks for the tip on the diagnostic port. These 85/86 machines are still a bit foreign to me, but I'm learning quickly.
sounds like you found the culprit.... a disconnected WOT switch certainly will be an issue..
#32
Supercharged
have you done any video tests to see what that splitter is doing at speeds over 100mph? thats a hell of a lever on the mounting hardware of the plastic air dam. is there support i cant see.... like it is really long under the engine. otherwise, you might want support wires. (ask me how i know. )
No, I've not done any video tests as of yet. That track you saw is pretty short (1.4mi) so top speeds are only around 90... well maybe 100 now with the fueling mostly resolved. It's a very stout member and is attached to the fenders and lower radiator support (not sure what you call that). It just butts up against the spoiler. But you make a good point. I should see what's happening and maybe put some turnbuckles in. THat's a nice easy project.
you should really get that camera mounted behind you so we can see driver input. Nice laps.. you need to really get the car in the lower gears before the turn in. especially like turn 1. leaving all sorts of time as well as control on the table. If you are doing that to save the motor, dont.... the track hot 928 needs the RPM higher in the turns or the oil flow falls off, and pressure goes down. plus with the RPM higher, you have much more rear end control with the throttle both in slowing and accelerating.
Yes... there is a lot of power being left all over the track. I was running a 1:29, and I should be able to shave 10 seconds off just with improvements in skillz.
the RRFR work great , as long as they are in working order. they either work, or leak in my experience with them.... the RRFR is much better for track duty and keeps the pressure up in the High rpm zones under full load. (WOT)
#33
How thick is the aluminum sheeting? if its pretty stout, it might not bend, and it will then be a question of the splitter pulling the air dam down. the pressure build up is about .11psi at 80mph and it goes up by the square from there faster.
at 120 to 130mph, all sorts of things happened to mine, made of thinner aluminum sheet. I had to add struts or cables to stabilize.
take a picture of how you have it built up and we can tell a lot about if it will be safe at the higher speeds.
as far as AFR control, yes if you are using the porken chip, then the designed regulator is the way to go because you are changing the injector duration for mixture, not pressure.
How do you know?
The PorKen chips were designed to work with the 87 FPR, so that's what I'll put in. Then I won't have to think about it. I'll keep this one as a spare/backup.
#34
Supercharged
I'd say it's about an 1/8" thick. Again it DOES NOT bolt to the spoiler. But there is quite a "lever arm" sticking out there. Getting a couple turn buckles might not be a bad idea.
You can see it here: http://perfexmfg.com/products.php
#35
yes, thats when most engines make their best power and are in the safest zone. 14.7 is stoich and thats where bad things will happen. highest egts and CHTs. thats ping-ville. above 16 is pretty safe too, and thats where you run cooler but lose power... and a lot of power as you go leaner and get into rough running-zone.
#36
kind of joking, yes, in a car it's not practical like it is in an aircraft to run "lean above stoich", but you can at near 75% power settings. but too lean is not good either as you get misfiring and then that produces contaminants that foul plugs and valves.
#37
put a couple of cables at least, if not 3, for when you get to speeds above 120mph.
here is what happens:
#38
Basic Site Sponsor
Basic Site Sponsor
Actually, what you really need to do is get the FPR for the 1988-1995 application, with the 16mm x 1.5 threads. I make a custom line that goes from this regulator to the "early" fuel cooler (instead of that two piece hose set-up with one hose rubber, the other hose plastic, and that crazy adaptor on the back of the block....what the hell were they thinking?) This is what I do for "early" 1987 street cars and 1985-1986 cars with Porken's chips.
If someone has a race car and is not running the fuel cooler (no A/C, so it's not necessary), I also make a line that goes from the 1998-1995 regulator directly to the junction block on the firewall, eliminating another couple places for leaks to occur.
"Race cars" need to be kept simple and have as few fuel connections as possible. Every connection is another place for a leak to occur.....and adds complexity that not only isn't needed but is also completely undesirable.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#39
Archive Gatekeeper
Here's the world's worst pic of Greg's FPR to hardline return hose:
#40
Basic Site Sponsor
Basic Site Sponsor
16 to 1 is only going to work on trailing throttle and perhaps in very low load for very short distances.
Engine damage will occur attempting to maintain freeway speeds on level ground.
#42
interesting that lycoming would disagree with you entirely. point is moot, in that it would be hard to get a car to tune at 16:1 anyway, but in actuality, it wouldnt ping there. just be low on power.. very low! in fact, calculated egts and chts would be the same if the car was running at 8:1. you see greg, as you go lean, the temp goes down substantially, right up until you start to miss. as does the power too, so the entire discussion is just that..... a discussion.
#43
Isnt it funny how my car has held together over 15 years of racing while others are blowing up left and right? hmmm maybe i have learned things from those that are or have been doing it right.
If i remember correctly, anderson and Fan had the same tune as i did and their cars ran pretty well. they put out 410 rwhp but had intake mods, hotter cams, drysump (marks) and bigger port headers and bigger valve heads. mine at 380rwhp is not too far behind...... but what do i know!
#45
14:1 danger
14.7:1 pinging and things blowing up
16:1 not much danger
17:1 no danger
18:1 no heat, but no power and misfires
Danger = high CHT and EGTs
