86.5 S ( How many)?
86.5 S ( How many)?
Now being the new owner of an 86.5 S it would be interesting to know
when they went to the 5 liter motor and how many 5 speeds did they import to the US. There appears to me a lot of mention of S2's and S4's but very little for S3's which I understand this car is.
Archive Gatekeeper
434 U.S./Canada 86.5 5-speeds. All but 6 had sunroofs, 222 had LSD.
Archive Gatekeeper
Limited slip was a $595 option in '86, for whatever that's worth. Not sure how much of a deterrent that would have been given the $50,000 base price.
The cheap bastard who bought mine didn't bother with an LSD. He clearly was not thinking of the car's future owner's wishes...
The only options on mine are LSD, sunroof and higher capacity AC
Rub strip delete .
The PO installed a rear sway bar from Devek. What is the advantage?
Thanks for the info
Rub strip delete .
Thanks for the info
Rear sway bar will keep back end of car from leaning as much. Of course, without a commensurate change up front, and depending on the width of the tires you are running, things can get all kinds of Caddywhumpas. Rub strip delete is a good one.
928 Owners club page has a lot of production numbers via the 928 Registry, IIRC.
A stock 928 understeers by design and fitting a stiffer rear end reduces the amount of understeer and can change the balance to oversteer. This is what the Louie Ott adjustable rear links do. Maybe that is what is fitted?
Rgds
Fred
I am waiting to get the car and see all the Devek bits that have been added to it. I know it has Koni coil overs along with the added bar. The challenge now is getting a trucking company to haul it from Canada to the west coast. This has become more complicated than first thought
