Looking for a CIS fitting M12 1.5 Male to M12 1.5 Male
All,
Just back to working on the 928 after moving, new house, new job, and a new baby (life is crazy).
I put all of the intake and injection system back on my '81 Euro S 5 Speed and now I am 1 fitting away from being able to start it for the first time in a year.
I need the fitting which connects the passenger side of the WUR to the fuel line return to the FD.
It is the fitting that is the same size and thread on both sides. From what I can tell it is (M12x1.5 AN Male) X (M12x1.5 AN Male)
Thanks all for your help.
Just called. No luck.
They have a bunch on AN stuff and Metric stuff, but nothing that is Metric to metric.
I have many spare M12 1.5 to M10 1.5 fittings. If I cant find what I need I may end up making it. I figure I can TIG weld additional material on the small end of another fitting, Turn the welded part on my lathe to a cylinder, use a die to cut the right size threads, and run a dill bit through to clean the port. Would probably take about 1.5 hours to complete, but I'm not sure I have a choice?
Archive Gatekeeper
Did you try Greg at J2 Precision? He's got an entire wall of metric fittings and adapters, he may have what you need. 714 879 9072.
Special-t-auto also has some fittings on their page. Always thought of trying their CIS fuel pressure gauge, back when I had a reason for it. Picked up a double banjo bolt for the WUR at one point.
Basic Site Sponsor
Basic Site Sponsor
Simple. 149-M12P.
$7.50 plus shipping.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
CIS WUR fittings
Sorry to rain on your parade, but I make the threads in the regulator body M10x1 and M8x1. This is an -086 WUR, but I doubt the cast iron body varied in its threads for any WUR model.
JP 83 Euro S AT 56k
JP 83 Euro S AT 56k
I found a CIS specialist in Texas
Link: http://www.specialtauto.com/delorean...injection.html
I believe I have the proper fitting on order. As mention by a couple, it is a M10 fitting, not a M12 as I originally thought.
