Sticky Emergency Brake
Took the boys in the P car to the ice cream shop last night in the '87 S4. Now up to about 24.5k miles. I had set the emergency brake when putting her in the garage, but I released it and left her parked there. When taking the car out last night, the brakes were still set but released when I put it in reverse and gave her a bit of throttle. For clarity, it had been about 6 days between use.
Is there a procedure about lubricating the cable or something? They obviously didn't release properly when I pushed the lever back down.
Thanks,
Cameron
'87 S4
Thanks,
Cameron
'87 S4
Inspect the cable first, from the parking brake lever to where it enters/exits to the exterior. Detach the mechanism covers along the drivers sidewall. Inspect attachment and tension. Note where it exits interior, then you can trace where it exits to the exterior. Make sure it is seated OK where it exits and is not the 'sticking/fraying point'. This is easier to do with the rear wheel off. Start here. Here is the schematic for the lever.
Team Owner
Thanks for posting a picture Craig.
Follow Craig s instruction to inspect the handle linkage.
Properly adjusted,
the E brake handle will do about 2 to 3 clicks for full engagement.
To adjust the E brake,
adjust the shoes at the wheels first.
Once the wheel shoes are adjusted then the handle is adjusted.
NOTE since this handle adjustment was done at the factory,
it is usually just the star adjusters that need to be readjusted to return the system to proper operation.
At the wheel ,tighten the star wheel till the rotor is just locked, then back off 3 to 4 clicks.
Do both sides, then set the handle,
you should have 2 to 3 clicks of handle travel.
Release the handle then see if the rotors turn freely,
if not then back off one click more at the star adjuster for the rotor thats dragging.
If the rotor still has drag then its possible that the E brake cables are dragging,
spraying them with lite oil may free them up.
Sticky cables are not usually an issue. BUT anything is possible.
Have a helper actuate the handle ,
and observe how the junction actuator functions parts 21 and 26 at the center of the lower cross member, you should see both cables pulling equally
then go to each rotor and with your helper working the handle,
see how many clicks of the handle it takes to stop the rotor,
both rotors should work equally.
If one rotor stays locked then the cable may have to be replaced to restore proper function.
Properly adjusted,
Team Owner
it depends on how you adjusted the brakes and how new the shoes are as well as how new the rotors are and how much traction the tires have,
NOTE always test pull the handle after installing new rear shoes then adjust the brakes.
NOTE if after adjusting the stars and the handle comes up past 5 clicks then you will make adjustments to the cable assembly under the cover at the rear edge of the driver seat.
NOTE there should be a spring installed to pull the cable back to release it this is also under the rear of the handle cover
Team Owner
Trax if you follow my instructions the E brake will hold your car on any hill
I was more concerned with the emergency brake being able to lock the rear wheels while driving in a straight line. Is this something the brake should be able to do? I can't find it covered in other threads, or even asked for that matter.
If the sole function of the brake is to slow down the car, or prevent it from rolling down a hill, that's one thing. But if it's designed to lock the wheels, than I need to further adjust my cables. I've had cars where the hand brake can lock the wheels, and some where it can't.
Team Owner
I will caution you as to trying to set the brake while moving.
what can happen is that the backing plate and the shoe anchors can be bent by the sudden locking of the E brake while the car is still traveling.
The possibility exists that the brakes could then jamb on and thus the wheels will stay locked and not release
Shameful Thread Killer
Something else I can say with confidence, the E-brake handle, cables, and hardware seems very robust. Cuz I pulled the living shilt out of it a couple times expecting it to fly apart, and it didn't. I've also found that the external cables and levers down by the rear axle do get a fair amount of corrosion over the years. Cleaning and lubing works wonders to improve operation.
