82 five speed fuel question
I need a picture of the fuel damper setup on an 82.
The newest project I have does run, but the PO has butchered the fuel and vacuum system. I am currently ripping it all out and returning it to original.
Would someone be so kind as to send me some pics of the fuel equipment near the front of the spider. I have most, if not all the parts, just need the pics.
Here is what he took out (cut it- geez)
That's the fuel pressure regulator.
What pics do you need exactly? I'm near an L-jet car for the moment.
The hard metal line attached to the front of the intake is for the vacuum modulator to the AT.
Looks like you might need a new engine harness if the same PO did some work on it. Someone has been in there.
Ok, looking at PET, it says this is the fuel damper, and he ones on each side are the FPR....unless I'm looking at pet wrong.
I need a pic of what I have , where it is supposed to be. I think I have replacement hard lines in my parts pile, I just need the orientation so I can restore it back to normal.
Thanks!
Thanks!
