928 Forum 1978-1995
Sponsored by: 928 Specialists
electrical to the 044 pump
Old 06-29-2015, 08:42 PM
928mac
928mac's Avatar
Default electrical to the 044 pump
I heard that the stock wiring will not run the 044 pump. is this true.
if it is true does anyone have a pic of how they installed and connected the electrical.
Old 06-29-2015, 10:38 PM
Ducman82
Ducman82's Avatar
don't believe me huh... :-( hear it from the master
https://rennlist.com/forums/928-foru...m-request.html
Old 06-29-2015, 10:56 PM
blau928
blau928's Avatar
I have an 044 pump on the stock fuel pump circuit for more than 8 years without any problems whatsoever.
The in tank filter was replaced when I changed the pump, and the fuel tank line also now has an AN fitting for the pump inlet to prepare for dual 044 pumps for a secondary fuel line.
I digress...
Stock, good working circuit will operate the 044 pump just fine.
Old 06-30-2015, 12:19 AM
James Bailey
James Bailey's Avatar
Internet "wisdom" shows it drawing about 12 amps which is low for a performance pump. Obviously a more direct electrical connection should provide a higher volume but adding a fuse, a relay, and a wire from the battery is not really necessary for most 928s.
Quick Reply: electrical to the 044 pump
