climate control upgrade
Can anybody post up the rest of this schematic? Want to see the lower part of this - where wires 1, 2 from the lower part of the setting motor go to. Also where wires 12, 9, 2, 1 from the control head go to.
And, what type of signal does the setting motor need to move?
Electron Wrangler
Here is the bottom half - it's from a 1990. This is not the same as your 1980 config - similar but not the same...
Thanks Alan. So if I read this right, the control head supplies a voltage to pin 12 on the setting motor, and the sensor string voltage is to pin 4 on the setting motor. I'm assuming the setting motor then has a certain motion based on the voltages it sees on these 2 pins?
Electron Wrangler
Alan
Ok, how about the following options to update the 928 HVAC control? Looking for feedback on these - pro/cons about each? These are late 90s - early 2000s Ford controls - mainly looking at these because of the vacume control built-in.
Simple 3 rotary **** system, with built-in vacume control. No Automatic temp control, so the resistor variance would need to be worked out to control the temperature setting motor. Might need a remote relay to power the blower fan through the resistor pack.
OR,
Digital version with Automatic temp control, built-in vacume control, funky rotary wheel for fan speed which definately needs a control box for the blower. The whole sensor string would have to be worked out to match with the 928 setting motor, but maybe not as hard as that sounds. Looks like Ford uses a similar temp setting motor with inputs like we have. Later versions of these can have dual AC, but no built-in vacume control, so have to work out the vacume solonoid control interface.
Pics grabbed from ebay.
OR,
Administrator - "Tyson"
IMO neither of those offer an "updated" look for the 928, especially the rotary **** one.
Electron Wrangler
I think you have to look towards german systems to get the right design styling - Porsche would never have come up with anything like either of those.
Perhaps something more like this general type .
Alan
Alan
That first one looks like the climate control in my wife's old cavalier.
The second looks updated, but not so much it outside the realm of period appropriate.
